Results 1 to 5 of 5
Coolant change question
    Wfd38383 wfd38383's Avatar
    Seekonk
    I am changing my engine coolant for the first time this weekend and I just have a question. When you refill the bike and start bleeding the air out of the lines how do you know when all the air is out of the lines? or do you guestimate?? Remember I am a complete newb on this.
    Lifer Wishbone's Avatar
    Jul 2006
    Re: Coolant change question
    put the new stuff in
    run it and when it goes down fill it
    let it cool, check it
    run it
    check it
    check your over flow
    wait a week and check it again
    Lifer imkindafkedup's Avatar
    Jan 2006
    Saugus, MA
    also i recommend adding about 1/4-1/2 a bottle of water wetter. I used honda coolant from the dealer before (even though i ride a kawi) and it all disappeared within just a couple minutes. That was with an engine with ti headers so the heat gets very hot, but none the less water wetter never hurts to add.
    Sep 2007
    Middlebury VT
    Check your manual.
    Use pre-mixed, aluminum safe coolant.
    Add coolant very slowly.
    Start bike and allow coolant to expand with heat, rad cap off.
    Turn bike off, install rad cap and top up overflow to it's marks.
    Check back in a week, keep an eye on temps during that period.
    Raymond NH
    Hey Eric, starter working alright?
    I have found that sometimes you get air pockets in the engine that cause overheating if you pour the coolant in too quickly. I siphon it in with 1/4" ID vinyl tubing. Obviously not all engines are susceptible, but it's easy enough to do, and a lot less messy. It does not replace bleeding either.
  1. coolant question
    By scr1be in forum General Bike Related
    Last Post: 04-09-10, 10:00 PM
  2. Coolant Change
    By rbrais in forum Bike Maintenance
    Last Post: 10-26-09, 11:04 PM
  3. Coolant Question - need answers!
    By Pleasegivesoap in forum Bike Maintenance
    Last Post: 09-17-09, 09:09 AM
  4. Exhaust change question
    By wfd38383 in forum General Bike Related
    Last Post: 09-28-07, 07:15 AM
  5. VIR Coolant question...
    By Jaynnus in forum General Track Day Talk
    Last Post: 03-20-06, 11:41 PM
