Results 1 to 9 of 9
Coolant flush and refill with distilled water?
    Senior Member kumpy's Avatar
    May 2012
    Norton MA
    I emptied the coolant out, closed it up, refilled with distilled water. Any downsides to running distilled water? Any benefits? I'm thinking if I crash on the track and leak out distilled water I'm not slicking up the track, but does water wetter or blue ice cool the engine better than distilled water?
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Coolant flush and refill with distilled water?
    Water wetter cools slightly better, as it breaks down the surface tension slightly.
    "Most" don't have a problem running straight water.
    Make sure you don't leave it in over the winter. It WILL cause a problem or 3.
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    throw some water wetter in there to lube up the water pump. realistically you should start the bike to circulate, drain, filll with water, and then add wetter. that way no coolant remains. and yes, drain and refill with coolant for winter.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
    I need to Pee! MellowYellow's Avatar
    Aug 2010
    Chicopee
    Alu likes distilled water. When I bought alu heads for my car the instructions specificly said use distilled water. Probaly because it has no hard chemicals to attack the alu.
    K8 GSXR 600
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    May 2012
    Norton MA
    Yeah, I understand about winter storage but I'm talking about for the track. Distiller water is cheaper than water wetter or blue ice.
    May 2012
    Norton MA
    Quote Originally Posted by 35racer View Post
    MoCool is the funniest name, perfect for Motul! That gave me a good chuckle.
    Quote Originally Posted by kumpy View Post
    You don't FILL the cooling system with Water Wetter... It's just an addative. I run straight distilled.
    "J.R.T.F.T."
    Apr 2011
    NH
    distilled water has no minerals in it which will leave deposits on the inside of the cooling system. Those deposits can build up affect the cooling of the engine.
    water wetter, as said, when added to the water it breaks the surface tension which is said to help the cooling but more importantly, it helps to lubricate the water pump seals.
    Tim
    LRRS #44
    Superbike Services 44
  1. Maytag Gas Range (Flush)
    By FlynGSXR1k in forum For Sale
    Last Post: 10-29-09, 05:41 PM
  2. storing bike w water/coolant
    By seth399 in forum Bike Maintenance
    Last Post: 11-22-08, 12:26 AM
  3. SV Flush mounts
    By mzdagrl in forum Bike Maintenance
    Last Post: 07-26-05, 09:57 AM
  4. coolant flush?
    By Matt K in forum General Bike Related
    Last Post: 12-20-02, 03:28 PM
