Results 1 to 15 of 15
coolest bike ever doesn't stay running
    Just Registered wingerdor's Avatar
    Feb 2008
    Upstate NY
    Now that I got you to click....Real title....250 nighthawk doesn't stay running.
    It is one of my training bikes and it's driving me to drink! (Not a bad thing really)
    It starts right up when it's cold and runs for about 15 seconds, then shuts off abruptly. Then it won't restart no matter what I try... crank it, choke it, throttle it, etc... Yes, there is gas in the tank! I have even tried hooking up a jumper pack to give it more cranking power.
    After I let it sit for about an hour, it does the exact same thing. Starts up effortlessly, then 10-15 seconds at the most, it stalls abruptly. I have tried this with the sidestand down, up clutch in/out... It doesn't seem to be any of the safety switches.
    Any ideas? HELP
    Ask me about Total Control ARC Level 1 and Level 2
    in Troy, NY and Loudon, NH
    John
    http://www.youtube.com/watch?v=fSVg3Gg4LmA
    '02 GL1800A Silver (Track Toy)
    '12 Striple R
    "I hope I always have a little more skill than stupidity"...Lee Parks
    Just Registered drop's Avatar
    Bradford, MA
    Re: coolest bike ever doesn't stay running
    not sure if your nighthawk has a vacuum operated petcock, but if so i'd guess vacuum leak preventing the tank petcock from opening.
    - Jamie
    2009 K 1300 S
    Jun 2005
    Float... Petcock?
    Sounds like it's getting a trickle of gas... enough to fill the bowl so it runs until the bowl dries out and either the float or petcock isn't letting enough gas in to keep it running. Let it sit while the gas trickles back into the bowl and it runs for a few and the cycle repeats?
    Lifer NobodySpecific's Avatar
    Apr 2008
    Burlington, VT
    Have you checked the air filter? I know it's not quite the same, but I was having a similar problem with my lawn mower. It would start fine, run, and then die. After a few times of that it would no longer start at all. I cleaned off the air filter and it started running great.
    '06 Triumph Sprint ST ABS
    '90 Yamaha XT350
    Member repsol_kid's Avatar
    Brighton
    are u def getting spark? thats the first place id start
    Oct 2009
    clogged fuel line, fuel filter?
    Life is good! gadget's Avatar
    Nov 2008
    Londonderry
    I agree with drop, Tricky Mike and qqac. It's a fuel problem.
    You are not getting a proper flow of gas and it runs for just long enough to empty the carb bowls.
    This could be bowl floats/needle valve, fuel filter, fuel line, petcock.
    Sam
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    After it stalls, take off the float bowl. If there is no gas, then this confirms that it is not getting the needed fuel once started. Then investigate the options listed above.
    When it stalls, immediately open the fuel tank. If you hear vacuum, it's the vent. Otherwise, all suggestions regarding fueling is where you wanna concentrate your efforts.
    Jun 2005
    Quote Originally Posted by Ken C View Post
    Well, there'd still be *some* gas... when I said "dry" I was being exaggeratedly.
    Feb 2008
    Upstate NY
    Thanks guys! It's cold now, so I'll open the fuel cap before I start it to rule that out. I can't imagine how the tank could develop enough of a vacuum in 10-15 seconds with a 250cc, but I'll try. Then I'm off to try the other stuff.
    {fingers crossed}
    John
    '12 Striple R
    Feb 2008
    Upstate NY
    No spark at either plug.... ugh!
    John
    '12 Striple R
    Lifer reiobard's Avatar
    Jul 2005
    Bennington, NH
    I am assuming that you pulled the plugs and watched as you cranked to see spark. Did you remember to touch the threaded part of the plug to ground to make sure it completes a circuit?
    Raymond NH
    Quote Originally Posted by wingerdor View Post
    Check the ignition pickup coil at the crankshaft with an ohm meter and a heat source. If it opens up hot, there's your problem.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    One of my buddies had this happen to him on one of his bikes once turned out his coil packs were bad. They would run for awhile then overheat and stop firing after they cooled off they would startworking again. Dunno if that's your problem or not but if you can't find anything else wrong with it...
  1. Honda Generator Won't Stay Running
    By Puppet in forum Bike Maintenance
    Last Post: 12-11-23, 03:07 PM
  2. dirtbike won't stay running
    By breakdirt916 in forum Bike Maintenance
    Last Post: 12-22-08, 08:51 AM
  3. Replies: 92
    Last Post: 12-06-04, 12:35 PM
