Results 1 to 21 of 21
What should I do?
    What should I do?
    Re: What should I do?
    For the oil filter?
    Push on the end as you try to rotate. If not, grab a cheapy piston ring compressor from Autozone and use that.....or get an oil filter wrench (NOT the band style)
    Dublin, NH
    I was thinking clean your bike.
    2023 KTM 890 Adventure R
    Its clean...
    Referring to the spotting though on the headers. Any concern?
    High maintenance priss
    Central MA
    RMWL?
    My first thought was that you are wondering where to safety wire. To the rad support maybe?
    [edit] Posted at the same time. Since you're talkin about your headers, see my first answer.
    Ray Viernes, Scammer! Ray-Ray's Avatar
    Oct 2009
    get new headers, or do some media blasting and recoat them with high temp paint/ceramics
    RMWL?
    English please.
    Oct 2009
    Ride more worry less
    Quote Originally Posted by Ray-Ray View Post
    Wise words.
    This wasn't like this last year...just noticed it the other day...help a noob out.
    Just Registered Doc's Avatar
    Jericho, VT
    How old is the bike?
    Sand paper, Scotch brite and some high temp paint...
    2002 f4i - only 6k miles.
    Central MA
    If the look bothers you: cheap route is scuff and hit w/ header paint. More expensive: ceramic coating. Otherwise i don't think you have anything to worry about.
    Very clean looking F4i btw!
    Oct 2009
    did you keep the bike out in the rain?
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Just ride it.. it'll burn off. Or like everyone else says, scuff it and shoot it with paint
    Posted by Jane in BoxChat
    Thanks
    Negative - had it in a heated storage unit from Dec. 1st to March 1st.
    Otherwise it is stored outside, with a waterproof cover, under a overhang.
    Just don't understand why all of a sudden it looks like this....
    Oct 2009
    I think you should sell the bike at a VEEERRRYYY low price to someone on NESR....then with the pennies you get from the buyer go out and buy yourself a new bike without header rust!!! Or, like what was said before....RMWL
    Condensation happens.
    Ill go with the RMWL route...haha thanks Ray.
    Oct 2009
    Quote Originally Posted by kazspeed View Post
    Thanks
    when the bike is covered outside, moisture still enters the inside of the cover....which then condensates..which get on your headers....and headers+waters = Rust....if that helps the "why" at all
    Scotch Brite pad + Mothers Mag & Aluminum Polish + Paper Towels
    apply Mothers to the pad and scrub away for a bit, it will turn real black, then wipe clean with paper towels. repeat a few times the first time you do it.
    i used to do this to my Buells SS header pipes about once or twice a season. works great and keeps the tarnish off for a while.
    Just Registered ChrisNoF4i's Avatar
    Jul 2004
    SoFla
    I recommend you stop being such a faggot.
    You're in the backseat.
    Support the Troops! (Except for Mondo, that guy's a dick)
