Results 1 to 6 of 6
Current draw for GPS?
    Member taxonomy's Avatar
    Northampton, MA
    I just wired a Tomtom 130 GPS unit onto the SV. I used the second heated vest outlet to connect the charger, so it's not switched. Does anyone have some idea of the current draw of a GPS in both the standby and on modes? My guess is this is going to be milliamps.
    Adam
    Me: "Normal people wouldn't do this."
    Peter: "First you have to operationalize with normal is."
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Current draw for GPS?
    Quote Originally Posted by taxonomy View Post
    Adam
    I don't have any numbers but it's power draw will be neglidgeable compared to the vest.
    Are you looking to see how long you can leave it plugged in before it kills the bike's battery?
    Northampton, MA
    Yeah, pretty much. I don't have it wired in switched. I can't imagine it's drawing much, especially when powered down. Tomtom does not give these numbers anyplace I can find.
    Powered down it must be mA, but does anyone have any idea about this? Can I leave it plugged in to the battery for, say, a week?
    Adam
    Ense petit placidam sandman's Avatar
    sema
    Adam
    my garmins powered down draw nothing. i don't have a tomtom to check.
    most volt meters can check amps, if you have one hook it up inline and check the mA with it off. or leave it hooked up for a day and check your battery's voltage before and after.
    jim
    "Molon labe"
    Northampton, MA
    I don't know where my multimeter is. Just moved a bunch of stuff around and I am leaving for the SS1K Saturday AM. Bikes are impounded Friday. I think it should be fine.
    If I am going to leave the bike for a long time I can always unplug the unit.
    I like it a lot. Pretty slick for $150.
    A
    sema
    Quote Originally Posted by 04ZRX View Post
    My Garmin draws 500 milliamps. That means your 8 amp battery will last for 16 hours before it is depleted.
    So, you are good for about 10 hours before you won't be able to start your bike. Or kill your battery beyond the point of re-charging it to a full 100%
    if you take out 5ah's from a 8ah (non deep cycle battery) your battery will be around 40% and i don't think it would start the bike.
    starting batteries aren't usually very happy with prolonged amp draws.
    if your 8ah battery was 100% around 12.6v depending on the battery 16 hrs @ .5a would give you 0v and a junk battery.
    as a general rule on deep cycle batteries you want to last, you don't discharge them past 80% and 90% is even better.
    so on a starting battery thats rated at 8ah removing 1.6ah's or your .5a draw for 3hrs shouldn't hurt the battery and hopefully still start the bike.
    btw: when my bikes are sitting i want no draw on them and usually have a fully auto battery charger on them.
    jim
    "Molon labe"
  1. LEDs and current draw
    By breakdirt916 in forum Bike Maintenance
    Last Post: 03-31-16, 10:50 PM
  2. current totals anyone?
    By F4Iguy in forum General Bike Related
    Last Post: 07-12-08, 03:16 PM
  3. Current Gas
    Last Post: 06-23-06, 10:50 PM
  4. Where do you draw the line?
    Last Post: 04-22-05, 06:00 PM
