Results 1 to 10 of 10
Metal chips in oil
    High maintenance priss
    Central MA
    Question Metal chips in oil
    I just put a magnetic oil drain plug on my 6R over the winter and the pics below are what I found after 3.5 TDs. I've never seen this amount or size of shavings in any other bike which I've put a mag plug in. Everything sounds fine, runs fine. Did valve clearances and a comp/leakdown end of last season and #s were great. Motor has about 12k miles on it: all street with ~10 TDs. Some searching shows that this still could be on the bounds of normal (and most likely clutch/transmission wear?) and I'm thinking to just keep a close eye on it between future changes. But...what do you guys think?
    Metal chips in oil-dsc03103-jpg
    Metal chips in oil-dsc03104-jpg
    don't care yasure's Avatar
    W.MASS
    Re: Metal chips in oil
    Hey man. I think your fine. I've seen that amount on many different bikes with no issues. Is this the first mag plug you put on that bike? Could be what was in the bottom of the motor for some time. If the motor is fine mechanically, I'd not worry. Just my 2 cents.
    Member CDOG1974's Avatar
    Apr 2010
    florence MA
    i would love to give you some info on that but at the present time i can't stop laughing at that avatar
    Lifer 03Worc9R's Avatar
    Worcester, MA
    That looks horrible. You will have lots of engine trouble and looks like you should get rid of that bike before something goes wrong. I will take one for the team and give you $1200. For the bike as is.
    Lifer Expat's Avatar
    Mar 2007
    Quote Originally Posted by 03Worc9R View Post
    $1201.........
    still a newbie j4eric's Avatar
    Aug 2009
    Grafton, MA
    ya...looks like your flux capacitor is at the end of its life......i will one up 03Worc9r and expat and give you 1250.00 cash for it.....
    08 CBR 1000RR street bike
    99 R6 track bike
    02 F4i sold to a nesr member
    Central MA
    Damn - its that bad huh?
    Aug 2009
    Grafton, MA
    the flux capacitor requires 1.21 gigawatts of electrical power to operate
    the 1.21 gigawatts are supplied by a plutonium-powered nuclear reactor and, with the absence of plutonium your 6r is dead.
    you aint getting the power with those metal shavings.
    99 R6 track bike
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Piston return sprig is wedding out. In all seriousness take a look at the chips after you dry all the oil residue off of them if there are no shiny parts to them and they are all discolored like they look in the pic, then they have probably been in there for a while. I'd just keep an eye out if this starts becoming a regular thing at every change with no signs of let up or they start increasing in size quantity, then I would worry about it, but for 15 k with no magnet before? Those could be left overs from the initial break in.
    KB KB's Avatar
    Manchester NH
    Stop changing the oil and ride it already.
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. CHiPs
    By SVRACER01 in forum General Bike Related
    Last Post: 01-13-17, 05:44 PM
  2. Metal to metal rear brakes
    By sedanman in forum General Bike Related
    Last Post: 06-05-15, 10:40 AM
  3. Removing Metal Chips From the Engine
    By jlawton in forum Bike Maintenance
    Last Post: 08-22-13, 11:40 AM
