Results 1 to 19 of 19
Dead fuel gauge...
    Lifer greenmonster's Avatar
    Aug 2003
    Dead fuel gauge...
    Put the bike back on the road today. Slipped in the battery, fired up no problem. Before heading out, I know I looked at the fuel gauge and it indicated full. This is before I started the bike and rode off. So, I go out for a ride, just happened to look down and the arrow is all the way down. Dead. Fuses are fine. Don't see any disconnected wires. I have zilch experience with electrical systems. To me, schematics look like a maze. Anyone have experience with this sort of problem and how to hunt down the cause? I live in Waltham, and can ride to whomever can work a fix with this. 97 kawi zx900r ninja, if that helps any. We'll settle up for your time, etc., plus I'll learn something in the process.
    Oh, I forgot to add, I charge double for Kawasaki's
    "My God, you're gonna have to cool me down, give me an ice block to shove in my pants or something".
    -Barbecue Lou
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Dead fuel gauge...
    Set trip meter
    get gas at about 125 miles
    Glen Beck is John the Baptist
    Aug 2003
    Quote Originally Posted by richw View Post
    Set trip meter
    lol...was hoping to fix what the underlying problem is.
    -Barbecue Lou
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    The gauge is simply a volt meter. Instead of 1 volt it says E. Instead of 6V it says 1/2. Firsrt put a VOM at the wire and see what it says. Then to bench test the sending unit you need a outside power source and a VOM and manually move the float up and down and check its output. The sending unit is simply a variable resistor.
    Aug 2003
    Mike, you just reaffirmed my lack of wiring and testing knowledge, lol. I know that what you're telling me makes sense to someone like yourself who can do it with eyes closed, and that's why I'd like someone to take a look at this. It's better if I see it and do it hands on...so if anyone has an hour or so, it'd be appreciated!
    -Barbecue Lou
    I work weekends and bust balls on this forum weekdays. A hour isn't much. I got nuttin to do weekdays if you wish me to take a look.
    In case the sender unit has to come out you should get a new gasket beforehand. Or else you will be referring to the other post about leaks.
    Aug 2003
    Looked around bikebandit today...didn't see anything about sender units, sender gaskets, etc. Just a few listings for Polaris and Yamaha. Even checked with sales/customer service. Told em I needed a fuel sender unit gasket. Instead, got a listing for the fuel gauge itself, lol. I've gotten a bunch of stuff from them, but no dice this time. I'll keep looking...I just hope the gaskets can be bought w/o having to get the unit along with it. Otherwise, I'll have to takes me chances with the original.
    -Barbecue Lou
    What are the chances that the in-tank float is stuck?
    Quote Originally Posted by greenmonster View Post
    It is possible to have a reuseable O ring too.
    Aug 2003
    A good chance, I'd say. Worth a look-see. Thanks for the heads up!
    -Barbecue Lou
    Aug 2003
    hmmm...do you mean there might be an o-ring in place with my sensor instead of a gasket? That would be great if it did. Now, to find out which it is...and the size should it need replacing. I'll call around to a bike dealer or two...see if they have parts lists/manuals that go back that far, lol
    Anyone know of a good dealer that carries kawi's? I'll check w/GBM, where I bought the bike.
    -Barbecue Lou
    Raymond NH
    Assuming the sender is bad, you'll need a gasket 11060-1337 and a sender 52005-1108
    Aug 2003
    Thanks, Dave! Where did you get these part #'s? They sure as hell aren't in online sites (that I've visited)...they all have the same schematics, and none list either the sender or the gasket/o-ring.
    -Barbecue Lou
    Raymond NH
    www.buykawasaki.com has full parts diagrams under owner info\parts diagrams. It's a bit hard to find, but they are comprehensive and handy. The part I listed has the float attached.
    Aug 2003
    ...now why didn't I think...
    -Barbecue Lou
    Northshore/Beverly, MA
    You got a PM my friend....
    Any Kawi parts fiche has it. I found it on http://www.midtownkawasaki.com/fiche...s&mfg=Kawasaki
    Aug 2003
    Thanks, guys, for the links and the parts #'s...Mucho appreciated!
    -Barbecue Lou
  1. Tire Pressure air gauge
    By 03Worc9R in forum For Sale
    Last Post: 08-08-12, 09:27 PM
  2. anyone have a runout gauge?
    By scubasteveRR in forum Bike Maintenance
    Last Post: 01-22-10, 10:32 AM
  3. WTB: 03-05 YAMAHA R6 GAUGE CLUSTER
    By CMG241 in forum For Sale
    Last Post: 09-21-09, 04:37 AM
  4. gauge LEDs
    Last Post: 07-15-06, 12:07 PM
