Results 1 to 25 of 29
How long will my Dragon Supercorsa Pros last?
    Member davemon's Avatar
    Sep 2007
    Bay Area, CA
    Hi Folks,
    At Tony's suggestion I have these on my SV650S and I really like them. My current lap times are about 1:27-1:29 and I have 3 days on them so far plus riding to NHMS from Cambridge and back. They look ok but I knom from higher performance car tires how heat cycles can kill some of the sticky ones well before the tread is worn off.
    120/70ZR17 Dragon Supercorsa Pro (SC1 - Super Soft)
    160/60ZR17 Dragon Supercorsa Pro (SC2 - Soft)
    I am asking as I am not using all of the tire yet in terms of grip or lean angle except possibly when I practice my braking and get the front "talking" (something I don't do to make quicker laps but rather for my own skill building). The concern is that I'm not knowledgable in how to handle a sliding motorcycle as I have only experienced very small amounts of spin-up under throttle in the rain thanks to smooth and slow throttle application. I would like to know when to expect these to change or if I can run them until the rubber is nearly gone with almost the same grip.
    Dave
    Re: How long will my Dragon Supercorsa Pros last?
    I'm running the same tires...
    I have one trackday ... and Renee has 2.
    Mine are still feeling great.
    I'm thinking they are good for 3-4 days at Blue Group speeds.... but will know for sure after July dates.
    FWIW, I change tires when I feel regular slippage where I don't normally get it.
    I prefer to spend $300 on new tires... than much more on bodywork and hospital bills.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Just Registered wookie's Avatar
    Sep 2006
    San Antonio, TX
    those are your street tires?
    What do you run if it is raining? Diablo rains?
    2003 R6 - Track
    2000 SV650 - Street/Track
    Me or Dave?
    As for me, I haven't run the new Dragon Supercorsa's in the rain yet... looking forward to comparing them to the PPRaces.
    Tony
    I've put about 10 track days & a couple thousand street miles on a set of supercorsa pro's before they finally needed replacing.
    Don't even bother thinking about heat cycles.
    FWIW... I replace my tires long before the tread is gone.
    I go strictly by feel. I start paying close attention after 3 trackdays.
    As mentioned though, I am looking for maximum grip and would rather replace tires one trackday too early... than one too late.
    PS... sometimes I'll back the pace down and practice getting comfy with the slides after the tires start to go away ... but more often than not, I replace the tires once they get fairly "loose".
    Tony
    Senior Member Hoss's Avatar
    Southern, NH
    10 days!?
    These things are compairable to Power 2cts as far as wear, arent they? I was thinking 3, maybe 4 days out of those even at my slow pace?
    Sep 2007
    Hinsdale, nh
    I just replaced mine that had 2 penguin, basic and advanced, 12 practices, and 7 races turning low 30's,replaced with new set last weekend.Buy the way I have a new set of Bridgestones for an sv for sale 220.00 front and rear I bought them and was going to try them but am going to stick with the Pirrelli's I am impressed.
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Quote Originally Posted by l3uddha View Post
    so without warmers start paying attention after 3 trackdays or so.
    how about with warmers on between sessions of each trackday?
    significant difference you think?
    I've noticed a slight difference since I started using warmers this year, but I still go through the tires just as fast.
    Sep 2007
    Bay Area, CA
    Quote Originally Posted by wookie View Post
    I typically run some take offs from the AMA Superbike series for my street rains unless MotoGP takeoffs are available at the time I need new rains for touring.
    Doesn't everyone?
    Dave
    I don't think warmers are going to affect your tire life enough to worry.
    And those of you getting 10+ days on the track out of tires... you're lucky or crazy.
    You're not seeing significant degradation in grip? Or you don't care?
    I think the fact that I swap rubber after 3 to 4 trackdays is another reason I've never had a trackday "incident".
    Tony
    Sep 2006
    San Antonio, TX
    Quote Originally Posted by davemon View Post
    Doesn't everyone?
    Dave
    too much working for me this weekend. Makes me grumpy.
    But, seriously, aren't those race tires? I really am not sure. If they are, it would seem that they would be scary in the rain.
    2003 R6 - Track
    I ran Michelin Power Races in the rain. The first two laps were scary, but after that they were fine.
    I'm hoping the Dragon Supercorsas are better... I've heard they are.
    Then again, I'm really hoping to find a front wheel for an 07/08 CBR600rr so I can throw some rain tires on the wheels. (I have the rear already)
    Speaking of which... anyone with an 03-06 CBR600rr need a front wheel... complete with rotors, etc?
    Tony
    Sep 2006
    San Antonio, TX
    Quote Originally Posted by 35racer View Post
    cool. I hear great stuff about the pirelli's...I think they are amazing. Someone told me they are the best tire for new racers because they tend to give up gradually, rather than suddenly ("tires for race retards" was actually the quote) That is the reason I use them for race/track days.
    but those tires on the street in the rain?
    2003 R6 - Track
    Sep 2007
    Bay Area, CA
    I thought you were joking in a sarcastic way... so I ran with it. Hope I didn't make you grumpier!
    I think mine are like DOT legal "R Compound" car tires. Something like a Falken Azenis R615 or some such... maybe a Toyo RA1 but they don't seem that sticky (those sandblast my car even before they warm up). The Diablo Supercorsa seem to be the most pure track tire of the bunch Tony sells and don't even have sipign in the center of the tire. If you look at the siping on my Dragon Supercorsa Pro tires you will see there is quite a lot of it except on the very edge of the tire (where I am NOT going in the rain).
    Diablo Supercorsa:
    Dragon Supercorsa Pro:
    This bike was purchased for track fun and learning, I won't use it for much else as my RT does everything pretty well and most things superbly well. It is actually so good that it goes CAAA CHING if it hits the ground and actually uses satellite to call the dealer and tell them how many thousands I am about to come over and spend.... thus the SV despite my plan to not let it hit the ground.
    Dave
    If you're gonna do a lot of street, I'd go with the Corsa III's first (but I only have 120/180 sizes so nothing for SV's.
    Diablo Corsa III
    Ken is running these tires and goes quite well.
    They will give you some more life... at the expense of some grip.
    The dragon supercorsa's feel really good on the track... but can't say I've used them on the street. I will say they seem to warm up faster than most race tires I've used.
    Tony
    Sep 2006
    San Antonio, TX
    No, I was just saying I didn't mean to be an asshole. I was just suprised to see someone actually running race DOT on the street (even though they are "DOT").
    2003 R6 - Track
    Sep 2007
    Bay Area, CA
    No worries, I didn't even know they were that extreme. I rode 15 miles in the rain on the way home from the last event and they seemed fine... but the only thing I pushed was the rear brake to feel for how much grip I had. I could feel them start to shudder and then break loose and the grip level felt respectable. It was still pretty warm though, close to 70F if I had to guess.
    Dave
    Lifer Jayspeed's Avatar
    Medford, MA.
    I swap to my street tires (Qualifiers atm) for street use 1. to have longer life out of my pirelli's at track 2. I wouldn't want to use them in the rain because the tread doesn't cover the edges of the tires. Other than that, these dragon pro's are amazing and for dry street riding they would be fine I think, especially in the recent heat. So far no slipping and 2 trackdays on them so far.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    I think Pete's post (10 trackdays)reflects the fact that he's riding a slow, moderately light bike.
    A 600 will toast tires more quickly due to it's heavier weight and higher HP. 4 trackdays seems reasonable almost regardless of street miles (unless they square off really badly).
    An SV could easliy go more than that. One season. Unless your times are dipping into the <1:20 range you're not heating them enough to cause performance to tail off due to heat cycles.
    Southern, NH
    So a 600 with a fat guy on it means 3, maybe 4 days then..
    damn i'm going to need a new set of these soon in think
    I've done 3 trackdays on them (one in the rain), and they were pretty squared off from all the street miles. I did a good job un-squaring them at the past two trackdays, but if I keep riding on the street until then they'll be just as bad again. I had scrubbed them close to the edge, but who really rides the edge for long on the street?
    this has got me pretty torn because i like the long sunday rides to NH and VT, but these tires felt absolutely amazing on 6/2 and 6/3 and i'm not going to give up that grip. guess I should start saving my pennies...
    The "new Pirelli Dragon Supercorsa Pro's" are not race tires they are street tires.
    The SC1-SC2 ect. Are Race tires. Triumph doe not put race tires on the bike.
    Proof:
    http://www.us.pirelli.com/web/catalo...SA_PRO_HIP.xml
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    I was assuming a good blue group pace 1:23 and faster. Until you get there, just ride them until the wear bars poke up. You won't see any loss in traction.
    Worcester, MA
    go with what paul just said. when i first started racing my SV i could get a season out of a set. until you are going sub 23 repeatedly, don't worry about it.
    LRRS EX #165 (formerly)
    Nov 2007
    I am 'slow' and after two track days on the CORSA IIIs I saw the line between the harder and softer compounds becoming very discernable. Maybe This is because I stand the bike up more than necessary before getting on the gas really hard though.
    Otherwise... the corsa IIIs were great tires for me. Very good stick. I'm thinking I should get 5 track days out of them.... and then get some decent street mileage out of the center area after the TDs have toasted the edges. Might as well try to get the most for my money
    Zip-Tie Alley Racing
    LRRS/CCS #103
  1. WTB 120/180 Dragon Supercorsa Race Tires
    By FireboltEric_MA in forum For Sale
    Last Post: 09-23-09, 11:26 AM
  2. Replies: 0
    Last Post: 04-29-09, 06:43 PM
  3. FS: Perelli Dragon Supercorsa takeoffs
    By jc r6 in forum For Sale
    Last Post: 01-01-09, 01:05 PM
  4. OEM Pirelli Dragon Supercorsa's - FREE!
    Last Post: 10-13-08, 12:36 PM
  5. Pirelli Dragon Supercorsa's
    By Jayspeed in forum Pit Area
    Last Post: 03-03-08, 08:01 PM
