Results 1 to 14 of 14
Tender on all winter straight?
    Nov 2004
    Boston, MA
    For the folks that use a bat tender, do you just plug it in and let it go till spring, or on a week off a week.... can't remember were I read that it should be on/off... seems like a pain to remember though....
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Re: Tender on all winter straight?
    The whole point of the tender is that you never need to unplug it -- it monitors voltage and only charges when necessary. This is much better than the old trickle chargers that keep on charging away forever until the battery fails -- with these you did have to manually plug/unplug them periodically.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Nov 2004
    Boston, MA
    Quote Originally Posted by joeswamp View Post
    humm....I thought the whole point was that it kept the battery charged
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Dec 2005
    Near The Dragon
    Wirelessly posted (BlackBerry9530/4.7.0.75 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Quote Originally Posted by Manny
    Nope. A trickle chargr could do that.. As well as ruin yoir battery. A proper tender charges,checks,waits until battry voltage drops below a certain point, and then charges again.
    Get out while you can
    Find your own path
    I use an automatic charger and rotate it from battery to battery each week. I've been doing this for years. Three 4-wheelers, TL-R, the boat & the Corvette batteries all get their turn - one week on, 5 or 6 weeks off. Seems to have worked fine these last few years...
    Dec 2005
    Near The Dragon
    nice toy collection..
    but yeah, if you have one device and many batteries to maintain, that makes perfect sense.
    most people prefer a zero thought required solution.
    plug in when you put it away, unplug in spring.
    Find your own path
    granite state
    battery tender is the best thing ever. my quad drains the battery quick in the cold now its always fully charged. makes starting the a big single allot easier in the winter.
    Lifer brewmaster's Avatar
    Apr 2004
    Portsmouth, NH
    I have one of these Battery Minder. It has been working great. I used to have a Battery Tender but it fried for the second time so I decided to try a different brand. Just to explain though the Battery Tender lasted 10 years so it did a good job.
    M900ie
    SS750
    69 gas gusslin' Chevy
    LRRS EX #418
    Going fo the third year on my $30 battery tender. Not sure of the name, but his had a huge ac/dc converter as a plug with a yellow sticker on the front. Three lights that show when it has power, when it is charging the batter, and when it is monitoring the battery. has a quick disconnect line so I can go from jumper cable like clips, to round electrical connectors.
    plug it in, forget about it, and take the battery off it when I'm ready to ride in the spring. works great and well worth it.
    Worcester, MA
    Quote Originally Posted by Cerberus View Post
    thats the way i've always used mine.
    LRRS EX #165 (formerly)
    Yeah, we epitomize 'impulse spending'
    But in all honesty, even my method requires very little thought. I spend a lot of time out in the garage, I just swap it around every weekend. Doesn't take shit to remember THAT!
    Apr 2004
    Portsmouth, NH
    I do the same with my 4 different batteries, easy and keeps them alive! My car battery is pushing 8 years and still kicks butt. It will start a cold 11.75:1 compression engine NO problem every time.
    M900ie
    SS750
    LRRS EX #418
    Quote Originally Posted by BMFR6 View Post
    I do it the same way
    also, manny: make sure you change the oil in the battery tender every other week with some cheapo stuff, then replace it with better oil in the spring...most people forget this step and end up with a dead battery every year
    Quote Originally Posted by brewmaster View Post
    Figures! All this talk and my charger DIES! Too fookin' funny! Yip, just went down to the garage for a quick schmoke and realized the meter wasn't jumping around. Went over & gave 'er a slap, starts working again. By time I'm done my schmoke, nope. Flat again. Does shit like this really happen?
  1. Battery tender 800
    By shashankmittal in forum For Sale
    Last Post: 11-01-12, 11:58 AM
  2. Battery Tender
    By tsorfas in forum Bike Maintenance
    Last Post: 02-08-12, 10:12 PM
  3. Battery Tender?
    By Hauptman in forum General Bike Related
    Last Post: 10-22-08, 11:09 AM
  4. Battery Tender Vs BT Jr.
    By HBerry in forum General Bike Related
    Last Post: 11-18-04, 08:42 AM
