Results 1 to 25 of 50
So, I need a motor
    Jun 2005
    So, I need a motor
    The CBR blew up yesterday. Haven't torn it down yet, but it sounds a LOT like it threw a rod.
    Already have a call into Hobbs to see if they might have anything in the replacement powerplant department.
    It's an 05 600RR that had an 03 motor in it.
    So, it seems at least between 03 and 05 will work, maybe more? Is there an easy way to check what years will fit in this frame?
    The current plan is to buy a used motor, salvage whatever I can of the HRC stuff in the blown motor. A lot of the HRC stuff is in the head and with any luck that's OK.. Also has undercut tranny, shift kit, etc... so that stuff is also probably OK.
    Actually, I'm not entirely sure what the point of this thread is....
    If anyone has some (reasonably decent) advice feel free to offer it up.
    Jul 2008
    Marlborough Mass
    Re: So, I need a motor
    bad day for hondas
    best of luck dude, check on 600rr.net or 1000rr.net those guys should know
    live to ride seth399's Avatar
    Feb 2007
    CA
    sorry for your bad luck dude, I am not of much help but will buy you a donut.
    LRRS #399
    MX #505
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    Im sure you already know but the WERA forums always have motors kicking around.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    I've gotten stuff from this guy in Nashua, Drumhillcycle.com Seemed like a decent guy, treated me nice anyway.
    Posted by Jane in BoxChat
    Jun 2005
    Thanks.
    Ryan Hobbs is on the case...
    Nov 2007
    You and I are master Honda diasassemblers as long as there is some beer to fuel us. Let's do it up! Gonna be a long winter...
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Westford, Ma
    Mike,
    If you need a hand taking it apart, you know I pass by every night just holler.
    Doug
    Jun 2005
    Cool... Not in a huge hurry. I'll probably tear into it this weekend just to get an idea of what I'm dealing with. The real work won't start until I have another motor. Maybe I'll be surprised and my motor won't be THAT bad, but my guess is it's not very likely.
    That didn't last long. When you bought that bike I couldn't help but think it would pop. I've had bad luck with any motor built beyond stage1. (except my GPbike, but I did that progressively and adjusted maint to suit each change.
    Jun 2005
    Yeah, I had considered the risk as well. Given how common these bikes are I figured if I ever found myself in this position I'd just swap the motor out for a reasonably priced used stocker and either steal what I can from the go fast parts or sell them to recoup some of the cost. The whole thing is still pretty speculative, though, until I get in there and see what's up. I admit, though, it would have been nice if it lasted longer, but that's the breaks. I feel confident that it was built well. These things just happen.
    Westford, Ma
    Never a truer statement with a race motor.
    Nov 2007
    Something tells me it will be easier to get the motor out of the frame than mine was lol
    LRRS/CCS #103
    who knows
    Pretty sure you can also use an 03 - 06 engine in this one since the 05 -06 years are the same.
    Let me know if you need a hand with anything. Don't know much but since I helped Degsy drop the motor out of MasterBombs 03RR I have been dying to see the engine tear down. I'll bring some beers
    Westford, Ma
    Quote Originally Posted by ceo and a bunch of numbers View Post
    Fuck Chris I've never seen a motor come out so hard..
    Raymond NH
    I have found that in most cases it's much easier to block the motor up from below, unbolt it, and lift the motorcyle off the motor.
    Nov 2004
    Boston, MA
    Tricky Mike takes motors out while sipping his morning coffee.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Just Registered
    Is it not obvious?
    Not sure ya still care but I am pretty sure anything 03-06 should work depending what kind of fuel plumbing and things you have (if you have any of the other stuff off the 05 or whats been kitted together). I believe some of the feeds were different but the bolt patterns should fly with 03-06.
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Jun 2005
    well, I tore the motor down today. Not nearly as bad as I had expected, but it does have some issues. A rod bearing failed and the crank appears to be bent... The rod itself (Carillo) *looks* OK. The bulk of the bearing was still in there and it doesn't appear to have suffered any metal to metal damage. I shut the motor down pretty much immediately when it started showing signs. Any thought on the likelihood that the rod survived? Does anyone have any wisdom about how I could confirm it's OK/not OK? I'm hoping I'm only out a crank and some bearings There are a handful of cranks on fleabay at the moment for under $100.
    sounds like a question for the Honda guy.
    *now paging Degsy*
    Westford, Ma
    can you get in magnafluxed? I might be able to get you a contact to do that.
    That's good news Mike! Maybe contact the folks over at NEP?
    CCS/LRRS #83
    Jun 2005
    Rod actually looks OK. Crank is bent to shit. I'm considering buying a stock crankshaft ($99 on fleabay), some new bearings, putting it all back together and seeing what it does... I just ordered some plasti-gauge. Gonna put a new bearing set in that rod, squish some plastic and see if the oil clearance is in spec. Honda makes 3 different thickness bearings, so I'm hoping I can get it right... if the largest bearing still leaves too much clearance I'm SOL.
    The rod is very likely just fine. They are very tough. Did the piston slap the head a bunch? There would likey be a lot of damage there before a rod would bend as those parts are aluminum vs a steel rod.
    Jun 2005
    Head is untouched by the looks of it. My main concern with the rod is that it's shows discoloration from the heat from that seized bearing. I'm worried it lost it's temper.
  1. Wanted - Parts & Tools | F4i Motor
    By Baggey22 in forum Wanted
    Last Post: 04-24-19, 09:23 AM
  2. Ninja 250 motor transplant... what motor to use?
    By DynoTune in forum General Bike Related
    Last Post: 01-06-14, 08:04 AM
  3. GS 650 motor WTB
    By FAST GSXR750 in forum For Sale
    Last Post: 09-18-09, 10:44 AM
  4. kx 80 motor
    By capt1014 in forum For Sale
    Last Post: 02-22-07, 11:36 AM
  5. wtb F4i motor[
    By rickmancc in forum For Sale
    Last Post: 02-06-07, 05:54 PM
