So how does one get a bolt with max strength locktite
loose?
I'm damn near stripping the thing... used a heat gun but
I'm getting afraid I'll burn/ melt things around it.
Trying to remove my scotts steering damper...
I have those odd headed security bolts so they seem easier to strip
than a normal hex bolt.
2008 Honda CBR 600RR
Air? I have no idea really.
or ask PK to look at it funny.
EVERYTHING is a repost
06 749R #0047
08 R 1200 GSA
13 Monster EVO 1100
Tap the end of the bolt in the same fashion as a nail. Don't smash it, just a firm tap should break it up.
Maybe even try tapping while attempting to turn the bolt...
Heat + Impact gun. Heat it with a torch, then hit it with an impact gun. The heat gun won't generate enough heat to release the loctite.
Oh and pray. Depending on the color, you could be in for a chore. Red loctite will come loose with an impact gun usually, heat makes it easier. From what I've been told, green loctite might as well be welded.
Give the bolt a good shot with a hammer. The vibration will break a part the locktite.
A torch will heat up the loctite and it will come right off. Like a plumbers torch. But if it is close to anything that can melt, good luck.
You might want to try this.....
http://loctitefreezeandrelease.com/
Its freon 134 in a can
Use of CO2 fire extinguisher old indian trick also for bearings
Note for rust nuts not loctite
Torch but use wet rags and aluminum foil to shield ajoining areas.
Glen Beck is John the Baptist
Another little trick I used to do is tig weld a smaller short bolt on top of the head of the stripped bolt. (The heat alone from the tig will loosten up the loctite) Then just turn the new bolt, and the old one will come out as well.
You can also weld a nut on top instead of a bolt. He will make his weld puddle on the inside of the nut so you can still get the socket around the hex of the nut.
Like many people said the way to remove the permanant loctite is heat. It says on the package to only use on bolts you don't plan on removing.
I use the med. stuff on most apps. I only use the high strength on rotor bolts
Think the dealer did this. Or I confused my Honda Red locktite (which is medium) with Locktite brand red which max strength. #^%$!
And scubasteveRR no not selling it. Just trying to get to my air filter
to get all the motor oil off of it after my hydrolock incident (see other engine seize thread). Anyway managed to slip the tank cover off with out removing the steering damper.
Akira - do you have a good soldering gun (not iron, gun)? Something along the lines of 200-300 watts. This can put a lot of focused heat onto a bolt w/o worrying about torching plastics/tank. Soldering Gun
Yeah...+1 on the heat, hammer tap and impact gun; feather the trigger will let the gun knock it loose. If a larger air impact, don't WOT unless you wanna see a tiny 1/4" torx drive shatter.
[QUOTE=idratherberidin;742271]Thanks for coming out of the arcade long enough to share this.
QUOTE]
Fair statement, but I do spend more time reading in the forum than it appears.
Alot of free time at work and bored so the arcade helps pass the time![]()
If all else fails, take a grinder and grind a slot into the head and try to twist it out with a flat-blade bit on a drill.
2023 KTM 890 Adventure R
Depending on the size of the bolt you may need more heat than a micro torch. A better option would be a Oxy/Mapp setup made by burnsomatic. This setup uses two small bottles and you can grab from home depot. The advantage here is that it comes with a small welding torch head that can be focused to a small point. This is $40 that really pays in the long run. You just need to know how to set up a neutral flame. This will give you clean focused heat without adding a ton of carbon.
Good Luck, Heat is the only way
Diablo Black 07 ZX-14
So I think the conclusion is that max strength stuff
does really have much application especially in locations where
its hard to heat. SuX! May have to drill it out when the time comes.
Not sure but I'd bet that the steering damper has some parts
in it that can't get too hot without failing.
