Results 1 to 15 of 15
ex500 tire pressures
    san fran
    what am i supposed to run for tire pressures? i dont even know what tires they are. they are 16s btw
    Lifer Pittenger5's Avatar
    Austin
    Re: ex500 tire pressures
    Depends on the tire manufacturer.
    Zip Tie Alley #505
    san fran
    bah guess i have to go out and look. man im feeling lazy today.
    Austin
    Haha, usually around 30ish, or a little higher seemingly.
    Zip Tie Alley #505
    san fran
    man your quick on the trigger today. thanks for the info. btw, the beast runs now!
    Austin
    Im horribly bored. And sweet, hopefully mine will do the same haha
    Zip Tie Alley #505
    Which 16's are they? Some are bias ply, some are radial. That could make a big difference.
    san fran
    well neither tire says bias ply on it, but both recommend 42 psi cold. so does the 30ish psi change? oh and they are both metzlers
    Quote Originally Posted by catch2otwo View Post
    You sure thats not 42PSI Max?
    its not the same thing
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    san fran
    Quote Originally Posted by BLACK SQUIRREL View Post
    it says " max load 550lbs at 42psi COLD"
    On the tire?
    Or on the Headtube of the bike
    Cause 27 cold is closer for Pirelli's at least
    san fran
    On the tire?
    says it right on the sidewall of the tire
    that's max pressure.
    the 16" Metzlers are the Lasertechs & they're bias ply.
    If you're not already a member, check in with the NEAR_EX500 guys at http://groups.yahoo.com/group/NEAR_EX500/
    That's the only resource I can think of off the top of my head that has knowledgeable racers with actual race experience on those tires. They can also help you piece together a 17" conversion kit if you so desire.
    san fran
    thanks pete, the front tire is a laser, the rear doesnt look to be. i poke around on the near list, but ill probably just lurk. i doubt ill do the 17in conversion now, moneys kind of tight and i have another set of wheels with good tires still.
    Worcester, MA
    wow, wow, wow. since when the hell did EX's get tires?
    LRRS EX #165 (formerly)
  1. Tire pressures during winter months?
    Last Post: 11-12-14, 03:28 PM
  2. Tire Pressures @ the track
    By Jim in forum General Track Day Talk
    Last Post: 07-28-14, 05:52 PM
  3. Street Tire Pressures
    By Doc in forum Bike Maintenance
    Last Post: 05-12-11, 03:55 PM
  4. EX500 Rain Tire Size
    By Gunner in forum Pit Area
    Last Post: 07-06-09, 10:29 PM
  5. Tire pressures, etc
    By TheIglu in forum Dirty Bastards
    Last Post: 10-27-06, 04:06 PM
