Results 1 to 9 of 9
Wheel Bearings
    Wheel Bearings
    Frenchy pointed out on Sunday that the bearings in my rain wheels are toast, which explains that ugly clicking noise coming from the wheel when the bike rolls.
    I know nothing about wheel bearings. Is it easy to replace, or will I need to have them pressed in? How does one check if the bearings are bad?
    I've got some time this weekend, and would like to get this done while I have the wheels off.
    Re: Wheel Bearings
    Rotate each inner bearing race by hand. Anything other than smooth, replace it.
    They are easy to replace for the most part.
    I'll send you a pic of what I use to press bearings. Slicker 'n' owl turd I tell ya.
    Re: Wheel Bearings
    and do bearings get replaced in the front & rear wheels, or it typically done in the rear wheel only?
    Re: Wheel Bearings
    They get replaced when they go bad.
    Re: Wheel Bearings
    Check out All Balls Racing. They sell wheel bearings for less than stock and they're as good, if not better.
    I use waterproof grease on the outside of the bearings on my rain wheels to prevent it from getting to the bearings. It helps.
    Jim. Order bearings from all balls direct. Get them delivered to my house. I'll put them in the freezer and we can install them this weekend. Takes 5 minutes.
    So these aren't typically replaced as a set? Only when needed?
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Wheel Bearings
    Yep only when needed but new ones are cheap and it is a good thing to do.
    As for install, looks like Degs has you covered. Basically you freeze the bearings and heat the hub. Bearings will pop right in without having to press them.
    Re: Wheel Bearings
    thanks guys. i just called and ordrered two sets to replace dry and rain wheels from All Balls.
  1. Wheel bearings?
    By nick5446 in forum Bike Maintenance
    Last Post: 02-13-18, 09:10 AM
  2. Wheel bearings... A cheaper alternative?
    Last Post: 06-07-11, 06:36 AM
  3. wheel bearings on a trailer - need help
    By Crash Dummy Denno in forum Bike Maintenance
    Last Post: 05-20-08, 08:09 AM
  4. How to install wheel bearings and oil seals
    By lucentone in forum Bike Maintenance
    Last Post: 06-30-06, 11:00 AM
