Results 1 to 11 of 11
Fixing Plastic Tank Inserts
    Windham NH
    I got a leak around one of the brass inserts in my KDX tank. Pulled the insert out and there is a small crack behind it. Advice on where to go from here?
    Lots of youtube videos showing people using a soldering iron, which is sketchy as hell. I dont understand how they don't go boom.
    Re: Fixing Plastic Tank Inserts
    My guess would be soldering iron temp is below ignition temperature for gasoline, yet above melting temperature of plastic?
    Windham NH
    I've been experimenting on a scrap handguard from the same bike. A heat gun is enough to get it melty. Still seems sketchy AF. Wondering if I should just use epoxy or something.
    Branford CT
    Sell you my purple kdx tank lol
    #277
    Windham NH
    It'd probably sell faster as is, lol
    Branford CT
    I just bought a kdx, has the awesome 90's purple accents
    #277
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    The key is managing the vapors.
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Empty the tank then melt? My limited experience with fuel & sealants/patches/etc is that it's impossible to get a good bond if there is fuel present - if it's clean bare plastic you might have luck with clearweld or something like that. But yeah, just melting some new plastic in sounds easier.
    05GSXR75005SV65090DR350
    I should show you the redone front fender I did for my sumo, filled the prior mounting holes, drilled new ones.
    Windham NH
    Jason's video was too long for me to actually watch and comprehend so I just gave it a rinse, filled it with water and went at it with the heat gun. Not leaking anymore, but I overcooked it and it's kind of ugly now.
    Expert Agitator
    Ashford, CT
    You're not going to get any sort of explosion by melting with a soldering iron. I've done light MIG welding on metal tanks and haven't had explosions. I have done more extensive welding on tanks and had some flames shoot out the open fuel fill. I had rinsed them out multiple times with water though to try and remove most of the gas and vapors. If you can leave it open to vent for at least a day you'll be that much safer.
  1. fixing a bent rearset
    By isaac_ in forum Bike Maintenance
    Last Post: 01-14-15, 12:07 PM
  2. WTB 2007 R6 Tank Plastic
    By OC_R6 in forum Wanted
    Last Post: 04-07-13, 12:07 AM
  3. WTB 05-06 GSXR 1000 tank plastic (small)
    By korndogg in forum Wanted
    Last Post: 04-12-11, 05:31 AM
