Results 1 to 7 of 7
In need of help please!!!!!
    Apr 2011
    I am trying to change the fluid on my clutch and I am having a big problem. I get new clean fluid coming out of the release valve, but i cant get the clutch lever to get any pressure. please help!!!
    Chris
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Re: In need of help please!!!!!
    What kind of bike?
    Did you use a Mityvac or something similar or just let it flow out? Could be air trapped inside.
    Apr 2011
    i have a 95 kawasaki gpz 1100. all I tried to do was attach a small hose to the bleeder valve, and open and close the valve and pull the clutch. this is the first time i'm trying to do it, and not sure where i'm going wrong.
    Crack the banjo at the master, pull clutch in, hold, tighten banjo, let clutch out. Repeat until you get a constant stream of fluid coming out of the banjo fittings when cracked.
    Other option is to use a syringe attached to the bleeder on the slave and push fluid back up into the master. Either way you need to get the bubbles out using the method I mentioned above.
    I93/495
    Read me All will make sense.
    More
    2012 Tiger 800 XC
    Apr 2011
    anyone in the Peabody area that wants to help?
    Apr 2011
    Thanks guys! I cracked the master banjo, as suggested. lever immediately got pressure and works great. Thanks for all the help and info guys!
