Page 4 of 4 FirstFirst 1234
Results 76 to 86 of 86
found an sv650
  1. #76
    Bullshit meter pegged scottfromboston's Avatar
    Oct 2009
    Maynard,MA
    Re: found an sv650
    Just buy the F*ing thing. You'll spend money on it, and learn how to fix stuff (which will save you money).
    You'd just spend it on hookers and coke otherwise.
    Quote Originally Posted by Sportygurl131 View Post
    i got recent photos,
    it was stored in a heated garage
    its very clean.
    im talking with him for a meet up time right now via email...
    right now i have him down to 500$
    adn it has a clean title etc.
    ~Scott
    2020 SMC-R
  2. #77
    Rocky Hill, CT
    Re: found an sv650
    My advice is to buy the thing. If it is indeed a clean titled bike then if you decide that you dont want it after you pick it up I will buy it off you for the $500 so you have lost nothing.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Re: found an sv650
    If its the wheel itself that's locked it could only be a seized caliper or bearing really. However if its the output sprocket that's seized causing the chain to bind and keep the wheel from rotating thats potentially a lot more serious. See if you can get the thing in neutral then unlock the axle nuts and with the chain off the rear sprocket see if the wheel will rotate if it doesn't see if the front sprocket will. If it does buy it no question lol. Calipers are tit to rebuild, trannies not so much.
    Re: found an sv650
    The clean titled frame alone is probably worth the 500 bucks.
  5. #80
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: found an sv650
    is it parked in gear?
    IMHO If it looks clean and you don't mind the fact you MAY have to put a motor in it... screw it, buy it. It could be something ridiculously stupid and the guy that told you it might be a fork lift bearing may just be too stupid/lazy to deal with it himself. Mechanics make fortunes off people like that every day.
    Get it running and you'll have a cheap spare bike for the track that you can add parts to as you need to and enjoy the (albeit slightly more expensive) process of building a track bike and learning to do so.
  6. #81
    NoChelmsford, Ma.
    Re: found an sv650
    Southington, CT
    Re: found an sv650
    $501...
    there is no way in hell your going to lose money on it...
    Buy it, figure out exactly what is wrong, if its going to be too much to fix, then part the fucker out, and double your money... hell a straight frame with a clean title, from a non-wrecked bike should net at least a few hundred bucks....
    Southington, CT
    Re: found an sv650
    Quote Originally Posted by PainfullySlow View Post
    don't you have a headlight wire to fix?
    Re: found an sv650
    did she buy it?
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
  10. #85
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    Re: found an sv650
    if this motor is popped then this will be a shit show... ask me how i know... i just went thru a rebuild of my sv and total cost incurred with a motor swap were over 1500...
    Tougher than a lion Sportygurl131's Avatar
    Billerica MA
    Re: found an sv650
    bike was sold...
    hehe geuss that means for me to keep saving for a track bike
    Quote Originally Posted by DuncanMoto
    Subaru love is so sweet.
    qoute from a fellow nesrian
    You crazy bitch!!
    2003 sv650s copper!
    Quote Originally Posted by Duffy View Post
    Sportygurl is probably your best bet for meeting and making new friends, she is like the social director or ambassador or something for NESR.
  1. 03+ SV650 Front Brake Calipers on 00 SV650
    By bergj1986 in forum Bike Maintenance
    Last Post: 06-13-08, 02:14 PM
  2. Half Squid found his new bike & I found mine
    Last Post: 07-30-05, 04:35 PM
