Results 1 to 22 of 22
Front Brake Pad Swap
    May 2012
    I got a set of Carbone Lorraine C59 Front Brake Pads for the SV.
    I remember hearing that you should scuff up the rotors with sandpaper and then use brake cleaner. Is this correct?
    If so, what grit sandpaper? My shop manual doesn't mention this step.
    Also, for a track bike do you use the brake grease on the back of the pads?
    Thanks
    Re: Front Brake Pad Swap
    What do you currently have on there?
    Can't say I'm 100% positive, but from what I recall, it's only necessary when changing pad compound type. Ie, sintered to ceramic or vise versa.
    Scuffing the rotors certainly won't hurt... but I wouldn't bother unless I had an issue.
    I don't use anything on my pads.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Wirelessly posted
    Im with tony. I wouldnt bother unless you experience glazing.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    While your in there give your calipers a good cleaning.
    http://www.youtube.com/watch?v=aHtxBI8NEMg
    Wirelessly posted
    If you are going to scuff, go with 600 and dont press hard and clean thoroughly with brake cleaner after.
    Apr 2011
    NH
    I second the cleaning of the caliper/pistons.
    All the crap that gets built up on them gets pushed back into the seals. It can cause the pistons to stick. I've had them stick on and drag and stick in an have way too much lever travel.
    I found a tooth brush and fresh brake fluid and a clean rag works pretty good. I've had someone suggest a pair of pliers that grab the inside of the pistons to spin them so you can get all the way around but I have not tried it. I've also taken the pistons out and cleaned them but that was only because I was having an issue with them.
    Tim
    LRRS #44
    Superbike Services 44
    Wirelessly posted (Doc sucks)
    He meant 60 grit. Not 600
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by Jimmy Faceplant View Post
    no way I would go that course.
    I'm just gonna send my rotors to True Disk but its also cause I think one of them is slightly bent.
    After seeing and hearing about there service I wouldn't waste my time....I would just send them to Truedisk...
    http://www.truedisk.net
    Dave must have seen me work my calipers and made a vid.
    May 2012
    Do you use dish washing detergent also?
    May 2012
    Hmmm, he recommends having your rotors sand blasted...my friend does have a sand blaster but I think I may just use emery cloth for now.
    Definitely need to clean my calipers. Thanks.
    Sep 2010
    Granville, NY
    I just give them a good scrub with red scotch bright to get the mung off them.
    Dish soap or purple power..
    Lifer SwiftTone's Avatar
    Norwood, MA
    I know my pistons were not coming out evenly. What are the risks of removING the pistons completely to clean them other than air bubbles?
    Wirelessly posted
    Quote Originally Posted by Pigman
    Confused the hell out of me.
    Dont send them to truedisk, send them to truedisk instead? Lol.
    Wirelessly posted
    Quote Originally Posted by SwiftTone
    If you use air you risk shooting yourself in the face with a ricocheting piston. Lol.
    Norwood, MA
    Wirelessly posted
    Huh? I think you're under the impression that I am going to use compressed air to take the pistons out? What I mean is, if I pump the brakes to get the pistons off the calipers, other than introducing air into the system are there any other risk of damage etc that I will be facing?
    you have to use compressed air.
    as soon as the 1st piston pops up from pumping your lever, you lose all pressure in the lines. so you'll have to use a C-clamp to hold that piston back in place, and use compressed air to pop out the other pistons.
    like he said, aim the calipers in a trash barrel, as they will shoot out quickly.
    Wirelessly posted
    Wirelessly posted
    If youre going to do a real caliper clean, replace all seals ( lubricate new ones with brake fluid) and pilish the pistons to a chrome finish with a gentle polish.
    Remove the calipers completely from the lines and clean them on a bench.
    Norwood, MA
    Wirelessly posted
    Thanks. I'll get to it eventually.
    OT but can you get me that receipt?
    Wirelessly posted
    Wirelessly posted
    Yup.
    Im redesigning my invoices. Give me a day or two.
  1. Front End Swap VS cartridges
    By tsorfas in forum Bike Maintenance
    Last Post: 12-29-14, 11:12 AM
  2. Front brake lever microswitch + brake bleeding
    Last Post: 05-05-11, 07:52 AM
  3. looking to swap the front end of my bike
    By jbman1983 in forum For Sale
    Last Post: 09-04-09, 02:47 PM
  4. Front wheel swap @ 50pmh
    By schleppy in forum General Bike Related
    Last Post: 03-05-09, 03:57 PM
