Results 1 to 16 of 16
HOT tip of the day
    FYYFF theothersean's Avatar
    middle of nowhere
    HOT tip of the day
    ever try to get the battery screw back into the post on a motorcycle battery? especially if you are adding accesories , you have even less thread to play with. I figured out a way to make it easier, before you unscrew the terminal and lose that square nut, slide the tip of a zip tie under the square nut then when you unscrew the terminal the nut won't fall down and when you go to screw it back in, it will get thread engagement easily , then just pull out the zip tie.
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    Re: HOT tip of the day
    good call. The guy I sold my bike to just had to do a similar thing to my ZX when adding some pigtails for a battery tender cept he used chunks of a popsicle stick & left em in there.
    middle of nowhere
    thats what I was doing tonight, adding pig tails for battery tenders ( err I mean the cheaper walmart trickle chargers that are only $18.44 each and work just as well as the $34.00 battery tenders)
    and when you have to buy 5 of them it can add up.
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    Posting Freak senecak19's Avatar
    Massachusetts
    Walmart charger... three years running.
    Just Registered wingerdor's Avatar
    Feb 2008
    Upstate NY
    Cool Idea, thanks.
    On a bike I bought that had side mount screws, I found that someone had snipped a little piece of the battery vent tube and stuck it behind the nut. Still there, real helpful
    Ask me about Total Control ARC Level 1 and Level 2
    in Troy, NY and Loudon, NH
    John
    http://www.youtube.com/watch?v=fSVg3Gg4LmA
    '02 GL1800A Silver (Track Toy)
    '12 Striple R
    "I hope I always have a little more skill than stupidity"...Lee Parks
    Quote Originally Posted by theothersean View Post
    you been peeking under my seat, why pull zip ties out, they stay in place perfectly fine amd are there for the next time you disconnect the battery
    you know who put them under my terminal nuts? my dealer
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Whoa. Randy...there's young'ns on the site.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    WALM*RT?! Fuckin pinko.
    wish I read this BEFORE installing my PCIII today and having that problem. iiiiieded up getting a flat head scew driver in there to prep up that square nut.
    I cut fuel line and put it under there. Works supah-good.
    KB KB's Avatar
    Manchester NH
    I just swear alot. Seems to work.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Senior Member Hoss's Avatar
    Southern, NH
    Quote Originally Posted by rmbbikes View Post
    +1
    Sep 2006
    Around the corner
    -1 ... no swearing needed
    I just flip the battery over and let gravity do all the work
    The rule is:
    you could always buy a slightly longer bolt/screw. it would probably cost all of a quarter at your local hardware store.
    middle of nowhere
    Quote Originally Posted by jcbell1007 View Post
    I thought of that but for some reason the battery bolt is non magnetic I am sure there is a reason for that so I didn't want to try a longer bolt.
    I know it isn;t magnetic because when I droped the one inside the bike , the telescopic magnet I have to retreve it didn;t work.
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    Superhero F4Iguy's Avatar
    Vermont
    im also thinking that if you had access to a soldering gun you could put a couple tacks on it, hold the nut in place, well, semi-perminantly.
    What?
