Results 1 to 11 of 11
MV Augusta F4 Coolant Leak HELP
    Nov 2008
    Framingham, MA
    Posted for a Friend,
    My buddy Ozzy, playtwo, just had a slider installed to his 2012 MV Augusta F4. His mechanic called to let him now that the bike is leaking coolant from the frame slider bolt. The only thing on the topic I found was that he may have pierced the coolant jacket: Leaking coolant from engine bolt hole? - MVAgusta.net
    Anybody here have any suggestions? For starters I told him to stay put, check the oil and not start the bike. Any ideas? Easy/Hard fix? anybody had this issue before?
    Any help would be truly appreciate. He is trying to ride NYST with us on Sunday, but more importantly I think that he does not want to loose his engine.
    Thank you!!
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    Re: MV Augusta F4 Coolant Leak HELP
    I'd put some teflon tape on the bolt threads and just keep an eye on it, if it were me.
    Lifer Pittenger5's Avatar
    Austin
    Quote Originally Posted by myzx6 View Post
    For the love of God if you use this advice, replace the coolant with water.
    That said, its probably leaking behind the bolt anyway (I would think)
    Zip Tie Alley #505
    Nov 2008
    Framingham, MA
    Thanks guys. He ended up taking it to cycle 128... apparently the Augusta mechanic is out this week. 150/labour hour I am told. Ouch. One expensive frame slider install. I am hoping that he will figure what's going on before the weekend and make it to NYST with us.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    It's totaled. Tell him to drop it off at my place and I'll find a scrap yard that'll take it.
    High maintenance priss
    Central MA
    Ouch. Mechanic isn't going to be able to do anything special. Either seal the end of the machined hole (or threads) really good or he's looking at buying a new cylinder. Might be able to plug the end of the hole w/ JB Weld or similar. Then cut the bolt down a bit to avoid bottoming out.
    Nov 2008
    Framingham, MA
    Makes sense. Thanks you sir. Will pass along.
    Apr 2014
    Riviera beach fl
    I assumed he was already running it with water because they are going to the track with it, but yea run it with water. Coolant is very slippery when it gets leaked on your tires, ask me how I know ( fucking Kawasaki putting a coolant reservoir right above the back tire)
    Lots of automotive engines have intake manifold and head bolts that go into the water jackets, Clean threads and silicone or teflon will seal it up just fine, just don't overtighten it because the sealer lubricates the threads.
    Nov 2008
    Framingham, MA
    Told him to call you Kian. Thanks
    Lots of automotive engines have intake manifold and head bolts that go into the water jackets...
    Say what?
    Please name a few so I can be sure to stay far away.
    Nov 2008
    Framingham, MA
    I assumed he was already running it with water because they are going to the track with it, but yea run it with water. Coolant is very slippery when it gets leaked on your tires, ask me how I know ( fucking Kawasaki putting a coolant reservoir right above the back tire).
    Yeap. He is using water weter.
    Say what?
    Hey buddy!! Long time no see. Yeap, seems to be the case with the August. Strange right?
  1. For Sale - Motorcycles | mv augusta
    By caloots in forum For Sale
    Last Post: 05-10-17, 12:09 PM
  2. The MV Augusta Collection
    By FirstDuc-1098 in forum General Bike Related
    Last Post: 07-07-12, 07:04 AM
  3. coolant leak test
    By Awesome in forum Pit Area
    Last Post: 07-25-06, 06:21 PM
  4. New Augusta
    By PinHead in forum General Bike Related
    Last Post: 01-16-03, 05:15 PM
