Theres a strong possibilty I may have to drain my tank and put in some fresh. I sta-bilized it in october, but replacing it is part of ongoing troubleshooting being done on my bike in an effort to isolate a problem with my engine's unexpected rough running and poor idling. (blue smoke out the can too) The tank is full...like 4.5 to 5 gals. My question is...how do you legally dispose of this much gas? Ive taken used oil to gas staions for recycling, but this gas issue is a first for me. Have any of you been faced with this? Or should I just say "fuck it" and dump it on my neighbors front lawn and toss a match?![]()
Find someone with a big old v8 truck and give it to them. I'll take it!!!
degsy
please don't dump on the ground
idea:
any water in there will sink..
separate it...
then filter the gas through a clean cloth... that ought make it
good enough for your lawnmower at least.
2008 Honda CBR 600RR
Why can't you just use it in your car?
EVERYTHING is a repost
06 749R #0047
08 R 1200 GSA
13 Monster EVO 1100
stick it in your car ... nothing wrong with stabilized gasoline ...
I thought about that...I was hesitant cuz if the gas is messing up my carbs (gumming) then wont that be bad for the car? The cars engine is FI. I did stabil the gas...and its not 100% known if bad gas is the problem, but its a consideration until the actual culprit is determined by looking at other possible causes first. I appreciate all the input.
just put it in your car, the gas cant be that bad. or find something to burn
Tuono
I had some bad gas in my tank a few months ago so I drained it. I only had about an eighth of a gallon left so I used it to give the wood in my fire pit a head start. That was not such a good idea. The flames had to have reached 15 feet. I probably didn't give my new neighbors a good feeling about me.
As you can see, you have plenty of options for actually using it. Any lawn/yard equipment (that doesn't use pre-mix) will run fine on it. So will your car. If you're skeptical, I'd bet you can find a handful of people here that'll take 5 gallons of stabilized fuel off your hands...![]()
It should pass through a fuel injection system OK. The higher pressures and pulsed systems don't get gummed up like carbs do. Plus - if you're putting it into a car tank you're diluting it with 10 or 12 more gallons of gas. Put it in the car and drive it. If you're really concerned, throw in a bottle of dry gas as well. Good luck...
SSearchVT
My wife wanted to make smores.At least you broke out marshmellows right?![]()
Even better!!!!!
bring it over to my house.. we can light the dead deer in my yard on fire.
Get an empty case of beer, a funnel, box of rags, dish detergent, and a zippo
The biggest fire i have EVER seen was a bean bag!
Wanna burn your house down quick throw one of those in there and drop a candle or something on it, and be sure to call the insurance co as you are running from your house( about 5 minutes from becoming just foundation!)
