Results 1 to 12 of 12
Anyone ever shortened their exhaust canister?
    Nik viva_brasil's Avatar
    Dedham
    Just wondering if this is difficult and if anyone has done this? I like the look and I just got a 2 bros full exhaust to replace the V&H slip on I have now, but the canister has some scratches at the bottom and I'd like to shorten it if it's not too much work.
    If anyone knows how to do this or knows someone that can do it please let me know. I don't suppose it would be too difficult... I just don't have the tools or knowledge of how to do it. I remember seeing a video on youtube on how to do it but I can't find it now.
    Also if you DON'T think it's a good idea, I want to know why...
    Thanks!
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Re: Anyone ever shortened their exhaust canister?
    All of the HAWKS in T1a have chopped them. It's easy.
    Things you need:
    Rivits & rivit gun
    Drill
    hack saw
    Grinder
    exhaust packing
    Drill out the rivits. Cut the outer can to the length you want. Grind smooth. Cut the inner tube by the same amount you just cut off of the can. Repack exhust. Place can on end caps. Drill holes in the can for the rivits. Rivit assembily. Put back on the bike.
    Carlsbad, CA
    I wouldn't be so quick to chop an aftermarket pipe. Chopping a pipe isn't necessarily all that difficult, but then again, stock pipes are usually not made of any special materials. If you have a 2 bros, is it carbon fiber? That might not cut as easily or cleanly as you think with a hack saw. Titanium? You better get a haaaarrrrrdddd ass cutting blade... Of course I'm not telling you that you can't do it or shouldn't do it, just be mindful that it's an aftermarket pipe and is most likely made with more expensive materials that may not like to be cut. On that note, I might chop my stock cans on my R1 and put race baffles in it, so good luck to you!
    Just Registered Doc's Avatar
    Jericho, VT
    My CF pipe cut VERY cleanly with a rotozip.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    yea i've done it....it aint hard....follow Gino's instructions and its easy as hell....maybe an hour's work.
    Waterbury, VT
    A simple way to mark a straight line - wrap masking or painters tape around it. If there aren't any wrinkles and it lines up - it's a clean straight line to use as a cutting guide.
    SSearchVT
    Also on the Yosh web site there is a vid on how to re-pack the can may give you some insight on how to do it but its not that hard...
    I used a piece of legal paper. Just wrap it around and connect the edge and tape the paper. Perfect line is set. Then take a sharpie and 1/2 on the paper and 1/2 on the can. Or you can spray paint it. Just make sure it is the end you are cutting off that gets painted.
    Leo loridin64's Avatar
    Outside Lowell
    +1 on the easy factor. just dont mangle the end cap
    2002 RC51
    USMC - Semper Fi
    POW/MIA - Not Forgotten
    What chicken strip??????? NEWTREADS's Avatar
    West Dover VT
    I was talking to a bike mechanic about that. He said that this will result in a loss in power. At the top end I believe. Not a ton but noticable. His reccomendation was to shorten the pipe a bit then go with a high mount exhaust to replace some of the length. Im not sure if its just a back pressure issue or if you can just re map the PC to correct for the loss in power. Might wanna ask around a bit more.
    Just my .02
    Quote Originally Posted by nilez View Post
    I put the baffles in the stock cans of the 04 R1 I had. It was easy as pie and sounded awesome...nice deap tone while keeping the sound level reasonable. The thought has been crossing my mind to do it to my 06 R1
    Apr 2006
    Beverly, MA
    It's not that hard, it just takes time to do it right. I ended up getting rid of my chopped canister because it was too damn loud. Then again, the can was only 6" long when I was done with it, maybe 7.
  1. Wanted - Parts & Tools | SV650 Exhaust Canister
    By AAMRR177 in forum Wanted
    Last Post: 02-14-21, 05:52 PM
  2. Replies: 0
    Last Post: 07-11-16, 02:51 PM
  3. shortened yoshi rs3 and practically new tires
    By martyk in forum For Sale
    Last Post: 08-04-13, 11:20 PM
  4. F4i shortened Scorpion exhaust
    By mlarivie in forum For Sale
    Last Post: 08-10-09, 03:44 PM
  5. WANTED: Hindle (or Similar) Exhaust Canister
    By MMPeter in forum For Sale
    Last Post: 07-24-08, 10:55 AM
