Page 6 of 7 FirstFirst 1234567 LastLast
Results 126 to 150 of 159
The (not so) Great Gixxer Rebuild
  1. #126
    Nov 2007
    Re: The (not so) Great Gixxer Rebuild
    Hey Jim do you work out?
    Zip-Tie Alley Racing
    LRRS/CCS #103
  2. #127
    Quote Originally Posted by ceo012384 View Post
    no never. i just got bicep implants. look for me on MTV's True Life: I'm Almost As Cool As The Kid Who Got Calf Implants
  3. #128
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Funny you mention that. This is going to sound long but, my best friend girlfriends sister is friends with this girl who is dating the calf implant guy from MTV true life. I met him once, weird dude.
    billy dont lie...that was you
  5. #130
    now that my steering bearings require adjustment, page one may help some members with questions on the process.
  6. #131
    spending another winter on the bike for posing season.
    took these with my shitty camera on my phone
    the nose has a scratch that Peach Pit will buff out
    The (not so) Great Gixxer Rebuild-2010-01-09-bike-front
    took the side fairings for Peach Pit to repaint. kickstand & stock clip-ons removed
    The (not so) Great Gixxer Rebuild-2010-01-09-bike-jpg
    cleaned the rotors with 60-grit sand paper. cleaned the wheel
    The (not so) Great Gixxer Rebuild-2010-01-09-wheels-rotors
    new clip-ons installed
    The (not so) Great Gixxer Rebuild-2010-01-17-clip-ons
    new Frame Sliders installed. fairing already cut
    The (not so) Great Gixxer Rebuild-2010-01-17-frame-sliders
    Pazzo shorties installed
    The (not so) Great Gixxer Rebuild-2010-01-17-pazzos-jpg
    Brembo 19RCS master isntalled
    The (not so) Great Gixxer Rebuild-2010-01-17-rcs-jpg
    front caliper rebuild. everything thoroughly cleaned & replaced all the seals. found out that I actually cracked the right one. ended up replacing that one.
    The (not so) Great Gixxer Rebuild-2010-01-24-caliper-rebuild
    all new stainless and pre-drilled hardware from Pro-Bolt. Have a new set of Performance Friction pads that I'll put in Sunday when I install the calipers back on.
    The (not so) Great Gixxer Rebuild-2010-01-28-brake-rebuild The (not so) Great Gixxer Rebuild-2010-01-28-brake-rebuild The (not so) Great Gixxer Rebuild-2010-01-28-brake-rebuild
    once the side fairings get repainted & all the parts are installed & torqued, i'll put up a final picture for the completed project
  7. #132
    who knows
    How hard was the Caliper rebuild?
    tricky thing is getting the pistons out. we used an air compressor to pop out the 1st piston out. then used a c-clamp to hold the 1st piston back in, and forcing the 2nd piston to pop out.
    then just thoroughly clean with a brake cleaner & a small wire brush. make sure you dry with air. the new seals popped right back in. lube the seals with some brake fluid before installing the pistons back in. check your pistons for scratches before re-installing.
    also remember to keep everything labeled for right & left calipers.
  9. #134
    Quote Originally Posted by DBKromz View Post
    tricky thing is getting the pistons out. we used an air compressor to very carefully! pop out the 1st piston out. then used a c-clamp to hold the 1st piston back in, and forcing the 2nd piston to pop out.
    Fixed. Those things come out like bullets.
    pads and calipers installed last night
    The (not so) Great Gixxer Rebuild-2010-01-31-brake-pads
  11. #136
    Jul 2008
    Marlborough Mass
    ill give you 5$ for you bike
  12. #137
    Quote Originally Posted by Mondo View Post
    only if you'll post it up for sale for $10 somewhere else the next day
    Last edited by Jim; 02-01-10 at 02:18 PM. Reason: not name-dropping other shitty forums
  13. #138
    Jul 2008
    Marlborough Mass
    who am I IOBOT?
    come on now...im not a DB
  14. #139
    Lifer Pittenger5's Avatar
    Austin
    who am I IOBOT?
    Hey, leave me out of this.
    Zip Tie Alley #505
  15. #140
    you ready for posing season
  16. #141
    So do these Suzukis typically need to be completely dismantled every year or something?
    Reason I ask is because I've never had to spend nearly as much time taking a street bike apart as what I'm seeing here......then again, I ride Yamahas and Hondas so maybe there's my answer...
    BTW; I'm really digging those wheels! Guy is selling a pair of Carrozzerias for my FZ1. Too bad they're 19-friggen-hundred!
  17. #142
    Lifer obsolete's Avatar
    Norf Sho
    No. Jim get's something into his head, asks questions not caring about the answer and then does what he wanted to do in the first place. It's a pretty known formula. He's also fat.
    -Alex
  18. #143
    live to ride seth399's Avatar
    Feb 2007
    CA
    AND street posing is serious bidness to boot.
    LRRS #399
    MX #505
  19. #144
    no, but i've heard it's good scheduled maintenance (i'm sure Noel will call me stupid now) to rebuild the caliper after so many years. my bike is approaching 8 years & near 30k miles. a $60 seal kit & an hour of your time in a heated garage over a boring winter seemed worth it to me. plus i found that my right caliper was cracked on the inside, so it was a good thing I happened to check.
    i've said it to many of you, i enjoy working on bikes more than riding them. so yes, i probably go overkill on winter projects on my bike. so where you may not want or need to do this stuff on your Yamaha & Honda, I'd probably be doing the same thing if I owned your bike instead of a GSXR.
  20. #145
    Lifer Fitz's Avatar
    New Boston, NH
    http://www.probolt-usa.com/
    Holy $hit. $texas!!! They don't kid around eh?
    Fitz
    I guess I just follow the mantra "Ride more. Worry less."
    BTW, when did Jim get all serious?
    When Degsy adopted him as his second son.
  23. #148
    Norf Sho
    He does so when:
    A. It's in a for sale thread
    B. It's his thread
    or
    C. He has no come back.
    -Alex
  24. #149
    Jul 2008
    Marlborough Mass
    He's also fat.
    agreed. He just hides it with bulimia
  25. #150
    He does so when:
    B. It's his thread that's not in off-topic
    or
    true, but slightly fixed
  1. first 2 stroke rebuild
    By black in forum Dirty Bastards
    Last Post: 01-25-17, 05:24 PM
  2. R6 caliper rebuild
    By Dip Dungles in forum Bike Maintenance
    Last Post: 02-19-13, 07:14 PM
  3. Great Ride Sat with great friends
    By GingahNinjah in forum General Bike Related
    Last Post: 05-21-12, 06:26 PM
