Results 1 to 24 of 24
I think she might hate me...
    Member Phate's Avatar
    Nov 2005
    NJ
    So after paying out of my *&^ about 2 months ago-ish for a full carb clean, tune-up, new tires, the works I get on my bike tonight and she will just not stay running. I warmed it up to about 150 before taking her out but as soon as I came to the first stop sign and the RPMs dropped all the way down STALL. Fire it up again and continue till the next stop sign and same gig STALL.
    I've had the bike back for around 7 or 8 weeks (I think) and only put on about 100 miles and none of those during the past 2.5 weeks because of work/rain gods. What the F is going on?!?!
    I had a similar problem with my truck one time and it was simply a loose battery connection but I'm doubting I'll be that lucky again. Thoughts and help?
    Edit: 2000 Suzuki GSXR
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Re: I think she might hate me...
    Moisture in your gas?
    Drain your tank and float bowl and start with new fresh gas.
    See if that helps.
    2008 Honda CBR 600RR
    serial lurker gs500fast's Avatar
    Sep 2007
    Belmont, Ma
    clogged pilot jet. seafoam or clean
    Just Registered Doc's Avatar
    Jericho, VT
    It's a GIXXA!!
    It's a GIXXA!!
    Dick
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer Wishbone's Avatar
    Jul 2006
    Quote Originally Posted by BLACK SQUIRREL View Post
    Dick
    Yes?
    O
    Not me
    This time....
    Probably need another carb cleaning. Sounds like a pilot jet.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Raise idle ?
    Glen Beck is John the Baptist
    Mar 2004
    woonsocket ri
    It's a GIXXA!!
    Dick
    Dick maybe, but at least he isn't a liar.
    NorthShore
    It's a GIXXA!!
    Damn, I hate hearing this stuff. When I bought my consignment Bandit 1200, I had the dealer do a 7500 mile and sync the carbs..Mine starts great, but most of the startup troubles I read are Gxxrs.
    Hmmmm..
    Hope it works out for ya. I left mine back at the house for 10 days. Filled it with Shell high test with Techron concentrate for 5 gallons. Hopefully that'll keep the gasoline, you know, GASOLINE, instead of jelly...
    Senior Member palanon's Avatar
    Nov 2008
    Epsom, New Hampshire
    Add some carb cleaner ( Sea foam etc. ) and run the tank out or just drain it. Fill up and add some more carb cleaner. Take a long spirited ride. If it will stay idleing, adjust to the proper idle r.p.m. and make sure it's running smooth. If not, you'll need to pull the carbs and clean. You may want to check to make sure your not getting crap from the tank fouling your carbs. After it has sat for a while, drain some of the fuel into a clear glass container and check for crap.
    Quote Originally Posted by toocrazy2yoo View Post
    Don't bother with high octane fuels. The Bandit is designed to run on 87-89 octane. Without engine mods and advancing the timing, it will actually loose performance running high octane fuels.
    " In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
    Southern, NH
    Quote Originally Posted by richw View Post
    Raise idle ?
    Action Figure Model SP GSX-R's Avatar
    Feb 2009
    Post Re: I think she might hate me...
    It's a GIXXA!!
    Gsx-R would be the proper term .... and ive never had any issues with mine
    Sladic aka Slush
    K7 GSX-R 600 - STOLEN JULY 16th 2012
    too bad you're not closer. TLRman is the mister wizard of carbs
    NorthShore
    Quote Originally Posted by palanon View Post
    10-4. Gotcha. But I'm back on the North Shore this week, the bike is down there in the garage sitting. The Tier1 Shell 92 is advertised no ethanol in Northern Va., sticker-verified by the State, and since I hate ethanol to begin with, for storage purposes, that's what I loaded it with. When I'm out riding every day, I use the 89, which they claim as 5%. For now, anyway. The 87 Octane down there is E-10. The book says to burn 87. But, the bike is air-cooled, and temps in the 90's compel me to use the 89. Pointless? Perhaps..
    Quote Originally Posted by DBKromz View Post
    As long as it isn't a Kawasaki.
    Nov 2005
    NJ
    Thanks for the replies guys. I am going to try to get some seafoam in the sucker and run it out to see if I can clear it. Just such a p.i.t.a. since I just dropped so much change into her so recently for a full carb cleaning. Blah, oh well. I will report back with updates.
    <---Thats a nice A$$! EFD 05 1K's Avatar
    Epsom NH
    I take it your gsxr is a 600? The 600's of that year were carbed right? My 2000 750 is fuel injected, i used to let mine warm up until right around 150 as well until i fouled a plug (not sure how you do that with FI) but now i let it get to around 100 or so and take off.
    05 Gsxr 1k Black/Silver, Yosh pipe, 8k HIDs, a very big grin
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    the 600's didn't go FI until 2001.
    Nov 2005
    NJ
    Correct 2000 GSXR600 = Carbs while 2000 GSXR750 = FI
    So on Sunday I raised the idle a bit and that worked just fine to keep the bike from stalling but how much of a "bandaid" is this? Should I just go through a couple of tanks of gas and crank through the gears before trying to lower the idle and see if that helps to fix or should I still do more than that? I can attempt the seafoam maybe over this weekend but what are the thoughts out there?
    Feb 2006
    Metro West, MA
    Back in June when it rained for the whole entire month I didn't use my bike for a good month (rain, work schedule, etc). When the rain subsided and I finally decided to start the bike up after a month I noticed it was running a little rough and the idle was way low. I adjusted it so it was around 1200 RPMs. Thought that it was kind of weird considering last time I used it, it was perfectly fine. So I filled the tank up with fresh gas and forgot about it and rode. After a good couple hundred miles of riding I noticed my idle was really high. So I adjusted it back down to 1200 and it's been fine ever since then. Only thing I could think of is that it sat for a month with untreated gas in the bike and got a little gunked up? After I rode those couple hundred miles back in the beginning of July it's been fine ever since.
    Nov 2005
    NJ
    Well she is now a bitch to start but with some finesse and time to warm up I can ride her. I raised the idle a bit and put some sea foam into the tank but there are some things that are obviously not right. So I now have the idle higher so that I don't stall but I started to get the "pop" backfire during some shifts. Also it takes a while to get her going to even be agreeable with me.
    Should I keep riding it as much as possible (which is truthfully not very much thanks to a nightmare schedule) and hope she smoothes out? Am I risking worse if I do this?
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Check and make sure none of the fuel lines are pinched or twisted under the tank. Otherwise take it back to the guy that did the work tell him its fuxxored and to fix it.
    KB KB's Avatar
    Manchester NH
    I see the sea foam bullshit has infiltrated another website.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Aug 2004
    Baltic,CT
    Syncing ? the carbs
    If one is almost closed or dead at idle those are symptoms
    or if one is so open it is idling the bike and others aren't doing it
    popping usually lean in cylinder
  1. I hate it when
    By theothersean in forum Dirty Bastards
    Last Post: 10-06-10, 08:32 PM
  2. I hate to do it but....
    Last Post: 03-05-06, 11:08 PM
