Page 1 of 4 1234 LastLast
Results 1 to 25 of 90
where to start?
    san fran
    88 EX500 Track bike Build
    ok so i picked up mike's 88 ex500 this weekend. its been sitting for two years. i haven't pulled it out of the truck yet but i figured id garner some opinions today. this is the description in the ad
    "The bike does not start, when I asked the ex guys they said it was something about the brushes and magnets for the starter that need to be cleaned. When you try to start it you can hear something spinning but that's about it."
    some of the other things i noticed was the front brake rotor needs to be replaced and the caliper needs to be rebuilt. not sure if the rear brake works.
    here was my to-do list.
    1. pull off carbs - clean
    2. drain fuel
    3. remove key cylinder
    any ideas on the key cylinder? i figure i can just rig up a switch for on/off and just have a push button start? just going to be a track bike so no worries about needing a key.
    Tuono
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Re: where to start?
    4. pull starter, clean brushes?
    san fran
    Re: where to start?
    not familiar with this stuff. im pretty confident with a wrench. is cleaning the brushes a fairly common thing to do? i need to find a manual for this thing.
    Tuono
    Lifer eboos's Avatar
    Re: where to start?
    I was going to do this with my bike too. My ignition switch is just a simple 3 way switch that shouldn't be a problem to change.
    san fran
    Re: where to start?
    Quote Originally Posted by eboos View Post
    good to hear. cant wait to dig into this thing.
    Tuono
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Re: where to start?
    i may have a manual still laying around for my old ex500.
    I'll see if i still have it, if so, it's yours.
    san fran
    Re: where to start?
    hey thanks biggi. ill shoot you a few bucks, let me know.
    Tuono
    Lifer Pittenger5's Avatar
    Austin
    Re: where to start?
    I have an electronic copy of the manual if you cant find a paper copy.
    Zip Tie Alley #505
    Re: where to start?
    http://www.cheapbastidracing.com/stu...ice_manual.pdf
    It's for the pre '94, but they're pretty much the same, engine wise. (except for the heads)
    san fran
    Re: where to start?
    excellent. thanks guys
    Tuono
    May 2003
    Charlton, MA
    Re: where to start?
    sorry, just took a look through the garage. Don't have it anymore. It may have been lost in the move
    Re: where to start?
    a lot of guys rig the key switch up the kill switch.
    off= off
    run= equivalent of turning on key.
    its pretty easy actually
    Lifer Punjistick's Avatar
    Norwell, MA
    Re: where to start?
    You can eliminate the turn signal controls by disconnecting the plug under the tank and inserting a piece of wire for a jumper. You can then use some safety wire and a washer to make a new choke. I have seen this on several EXs.
    san fran
    Re: where to start?
    off= off
    good idea sv. i like that. i need to get the tuono out of the garage so i can start working on this thing. pete i got that manual from your link thanks!
    Tuono
    Re: where to start?
    Quote Originally Posted by catch2otwo View Post
    Cleaning the brushes is tit as long as the starter is serviceable. Just make sure everything's completely dry before you put juice to it.
    Re: where to start?
    Good, I tried emailing it & gmail said it was too big
    san fran
    Re: where to start?
    o well thanks anyway. i have to dl it again on my home computer since it wont dl on this work computer. hopefully put some gas in it and throw a battery in it once i rig up the switch and see if i can bump start it.
    Tuono
    Nov 2007
    Re: where to start?
    off= off
    That's a great idea.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    san fran
    Re: where to start?
    ok. ready to put fresh gas in the tank. one problem. dont have a key for the tank. anyone know where to get one of those nifty keyless gas caps for it? and will i be able to undo all the bolts for it and take the stock one off without the key?
    Tuono
    Lifer JohnnyV's Avatar
    Westborough, MA
    Re: where to start?
    There will be a screw under the cap, so no.
    san fran
    Re: where to start?
    hmm so any ideas as to getting this thing off?
    Tuono
    Norwell, MA
    Re: where to start?
    jam a straight-blade screwdriver in and turn it?
    san fran
    Re: where to start?
    hope it didnt come to that. but it doesnt look like i have a choice.
    Tuono
    Norwell, MA
    Re: where to start?
    there is a little latch at the front of the cap (12 o'clock position as viewed from the seat) if I recall correctly. You might be able to push something in between the tank and the cap to get it to open but I'm not sure.
    Re: where to start?
    yeah even if you get all the bolts out generally the LOCK (ie:latch) hooks into the tank itself. screwdriver it is. OR...there may be a # on the bottom of the ignition, this will be the key # and you may be able to just get a replacement key if so desired
  1. 636 won't start
    By apollomx681 in forum Bike Maintenance
    Last Post: 08-18-08, 09:39 PM
  2. Wed, 7/9, start in RI
    By jeantarrou in forum Rides & Events
    Last Post: 07-08-08, 07:49 AM
  3. start um up let um run
    By beet in forum Bike Maintenance
    Last Post: 12-17-03, 07:47 AM
