Results 1 to 13 of 13
Clutch Pressure Plate Shattered
    Nov 2004
    Boston, MA
    2006 749R
    Dry Clutch, was leaking oil out the cover (which has a sound dampening gasket, not designed to have oil in it). Common problem on these bikes as a seal blows behind the clutch at the rod or something.
    When they (BCM) took off the cover they found the pressure plate shattered. Why the hell would that happen???
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Be Squid, Be Proud bostongixxer's Avatar
    Dec 2005
    Cohasset
    Re: Clutch Pressure Plate Shattered
    Because you were beating the piss out of it at VIR for two days...backing it in, etc., etc. If you rode a solidly built gixxah, you'd avoid these problems and go faster on the track.
    2020 KTM SMC R
    2006 GSXR-600 Race (LRRS #199)
    NO LIMIT
    Nov 2004
    Boston, MA
    Dude....this was BEFORE vir!
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Dec 2005
    Cohasset
    Well, you posted it today...how was I supposed to know your bike didn't blow up again like it did in NJ? ...I still stand by my gixxah observation.
    2020 KTM SMC R
    NO LIMIT
    Nov 2004
    Boston, MA
    Quote Originally Posted by bostongixxer View Post
    I didn't want to mention anything......BUT, someone at NJ told me they saw you doing inappropriate things to my bike.....now I find out the pressure plate was cracked.
    The I see you doing inappropriate things with my helmet fan.
    Discuss.
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Dec 2005
    Cohasset
    The fan is intended to cool, is it not? ...and it looked like my helmet fan.
    2020 KTM SMC R
    NO LIMIT
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Heat and cooling cycles = brittle
    Glen Beck is John the Baptist
    Nov 2004
    Boston, MA
    isnt it supposed to cycle and last??? the bike has 3K miles
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Lifer Wishbone's Avatar
    Jul 2006
    Quote Originally Posted by richw View Post
    If oil from a seal blew behind it, maybe the way the heat cycles happened it was in a way it wasn't meant to handle.
    Lifer obsolete's Avatar
    Norf Sho
    The oil behind it could have flash cooled it making it brittle. :shrug:
    -Alex
    Dec 2005
    Cohasset
    not the way you ride it.
    2020 KTM SMC R
    NO LIMIT
    unless you're a Kromz on a gixxah. avatar self explanatory.
    Jun 2005
    I'd think it'd require a lot of oil to quench the hot plate and cause it to turn brittle, but if that did happen it could definitely shatter. Usually it needs to cool in a hurry for any real molecular difference, no?
  1. Clutch plate install question
    Last Post: 08-06-14, 11:53 AM
  2. Ducati CycleCat pressure plate/Dry clutch.
    By fastfreddy333 in forum For Sale
    Last Post: 10-28-11, 05:53 PM
  3. Busa Clutch pressure plate I designed
    By brendanp in forum General Bike Related
    Last Post: 12-12-09, 08:03 PM
  4. clutch pressure plate tool
    By Truth in forum Bike Maintenance
    Last Post: 09-30-08, 03:16 PM
  5. replacing clutch plate
    Last Post: 07-05-08, 06:53 AM
