Results 1 to 8 of 8
Mityvac question
    Oct 2001
    Bedford, MA
    Mityvac question
    Ok, I have a metal Mity-Vac setup.
    Works great.. but I have a question about it.
    Mine has a jar, a hose to connect the pump to the jar, a hose to connect the jar to the bleed valve, and a whole bunch of smaller fittings & hoses to adapt stuff.
    A little while ago I had to rebleed my clutch after getting a lot of air in it. It took a lot of fluid to get it right again.
    So what happens is:
    1) I start bleeding, initially I suck out dirty fluid, empty the jar
    2) Once that's done I'm pumping clean fluid into the jar
    3) I have no way to send the clean fluid back into the master cylinder easily, so I fill from my container of fresh fluid.
    The thing here is I wasted fluid. No big deal as I still only used like .4L of fluid or so.
    But what what I get to set it up so the fluid went from the pump right back to the master cylinder so as to not waste any fluid?
    Is this even possible with a little handpump? Is it worth it? The way I do it I waste a little fluid, but I'm absolutely sure the fluid going into the system is 100% clean brand new fluid.
    Waterbury, VT
    Mityvac question
    It is possible, but it might be easier to remove the Mity-vac from the system and just use a longer piece of hose.
    Attached the hose to the bleeder valve, and make sure it is secure.
    Open the bleeder and pump out the dirty fluid into a jar using the lever, replacing with clean.
    When enough clean has been added - Put the other end of the hose in the fluid resevoir so that the end of the hose is completely submerged.
    Open the bleeder valve and slowly pump the lever, make sure the level in the resevoir stays above the end of the hose, and watch the bubbles. When no air comes out for a while, shut the bleeder and remove the hose.
    SSearchVT
    Mityvac question
    Just use new fluid, don't bother reusing any of it. Just because it's clear doesn't mean it's clean.
    No Post Count Lurker RGVER's Avatar
    Nov 2006
    Milford, MA
    Mityvac question
    +1
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Mityvac question
    I've used a mityvac before, and I'll be honest... not a big fan. I get better brake pressure just doing it the ol' fashioned way.
    Did you notice any spongeyness after your mity-bled them?
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Mityvac question
    Degsy trick clamp your brake handle up over night tie zap it or how ever. Release the brake handle & you will be amazed how well your brakes work.
    www.bostonmoto.com
    Forum Rules
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Mityvac question
    For mity vac to work, good the bleeder should be removed entirely and the tapered nozzle making a seal with the hole.
    If you have a helper and you have leakproof connections you can get a flow going constantly topping of the reservoir as it drains.
    The hope that the flow will entrain the bubbles and flush them out withthe fluid
    Even after its "GOOD" I come back a few days later after a ride and bleed the bango fitting at the master. Then its really solid.
    I think that the micro bubbles migrate up there over time
    Glen Beck is John the Baptist
    Oct 2001
    Bedford, MA
    Mityvac question
    So this thread is ancient now..
    I did end up getting my brakes working really well with the MityVac.
    I had a little issue with being a tard and not having my front wheel perfectly aligned in the forks.
    Fixed that and my brakes feel great now. (That was months ago too)
  1. Mityvac sale
    By jasnmar in forum Bike Maintenance
    Last Post: 09-06-13, 05:11 AM
  2. DEAL: Mityvac, $24
    By schleppy in forum Bike Maintenance
    Last Post: 09-03-08, 10:56 AM
  3. HID question...
    By viva_brasil in forum General Bike Related
    Last Post: 08-04-08, 07:46 PM
