Results 1 to 11 of 11
help with 07 gsxr 750 problem
    Newbie
    marblehead,ma
    bike keeps shutting off on me while riding.sometimes it will completely go dead, turning ignition on and off with no power.wait couple sec. and then it will come back to life.checked batt,leads ,connections,stator ,r/r,pulled out power commander,removed set valve.havent rode it since the pc has been out,any input would be greatly appreciated.
    Posting Freak boloson's Avatar
    Oct 2007
    Re: help with 07 gsxr 750 problem
    check your kickstand. i had a get off & had the same issues as u
    Jan 2009
    Waltham
    Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en))
    giving you any code? or throwing a redlight at the very least?
    Lifer Stromper's Avatar
    Eastern Ct
    find tip over senor push back on mount then zip tie
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    i would also think tip over sensor.
    Senior Member TimmyB's Avatar
    Southern AZ
    that would throw a code, though.
    Newbie
    marblehead,ma
    everything is flashing including the red light,but no fi code.i think that stopped after removing the set valve.i ve read alot about this problem.i checked the sidestand switch looks ok.i havent checked the tip over sensor,will do that next.going to take her see what happens. thanks everyone ill update later.
    Posting Freak senecak19's Avatar
    Massachusetts
    When you say checked the battery leads did you actually tighten them or just pull on them. I had a friend with the same problem and the ground just needed to be tightened.
    Wirelessly posted (BlackBerry8530/5.0.0.734 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    There is a connector under the seat. Jumper the black to the orange with ignition on to see the code and post the code here. Ill tell you what it means. Google to find the connector and verify the wires to jumper. There are threads around that you will find that tell you which ones to jumper to get the code.
    twisted gixxer frenchy21's Avatar
    Aug 2010
    east providence,rhode island
    i got the same bike, same year and mine did the same thing, i changed the kickstand spring and the little tongue on the kickstand that meets the sensor i pulled up just a little and it has never done it again
    Newbie
    marblehead,ma
    looks like the kickstand meets the sensor was the problem like you said frenchy21.riding good so far.thanks everyone for input.
  1. 2007 suzuki gsxr 1000 gsxr stator system
    By frenchy21 in forum Wanted
    Last Post: 07-19-12, 01:51 PM
  2. Replies: 5
    Last Post: 03-22-12, 09:42 AM
  3. Replies: 29
    Last Post: 11-21-11, 06:00 PM
  4. Replies: 6
    Last Post: 06-02-11, 09:14 AM
  5. Part outs RF, Gsxr 750, Gsxr 1100 Watercooled
    By Madmike in forum For Sale
    Last Post: 01-04-11, 02:02 PM
