Results 1 to 6 of 6
Need Some Help
    Southern, NH
    Question Need Some Help
    So, I was just on my bike, heading home from work
    and something funny started happening.
    While cruising at about 75 (6K RPM) I let off the throttle
    completely and i started to feel something slip...or not catch.
    I did it several times to make sure it wasn't just something in the road etc.
    Same thing. At lower speeds it is not as noticeable.
    I am thinking it is just a loose chain? The last time I had it tightened was about 6k ago. I do not lube/wax my chain as much as I should
    Bike has about 17K on the clock...2006 GSX-R 600
    I would really appreciate some responses/ideas/suggestions guys.
    Thank you in advance
    Jul 2006
    Hollis, NH
    Re: Need Some Help
    #1 - I know the 06 750 has a slipper clutch but I'm not sure about the 600. That means it's supposed to slip if you dump the throttle.
    #2 - 17K miles and poor chain maintenance could mean a stretched chain or worn sprocket. Put it up on a rear stand and inspect the sprocket. You can also spin the wheel by hand and see if the chain rides up on the sprocket at any point.
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Need Some Help
    Does it slip when you get on the throttle hard?
    Re: Need Some Help
    There's the problem.....your bike's clapped out!
    I'll give you $500 for it...
    Southern, NH
    Re: Need Some Help
    Quote Originally Posted by Cheese-GSXR View Post
    The 600 also has a slipper clutch I believe. I don't have a rear stand.
    I did inspect the sprocket to see if any of the teeth were "shark finned" but they seem to look good.
    The chain however does seem to be sagging a little bit.
    If the chain is stretched, is tightening possible or at 17k maybe a new one would be the best solution
    ZX-12R - Bill
    It does not slip at all when accelerating
    Southern, NH
    Re: Need Some Help
    ok.....deal
