Results 1 to 8 of 8
valve cover gasket
    wus good pimpin Truth's Avatar
    Oct 2007
    sin city,ma
    valve cover gasket
    ok so i was riding today and the valve cover gasket blew out. it blew out at the end where it is shaped like a half moon does any one know why this would happen? i have a 95 zx7r.
    Jun 2005
    valve cover gasket
    See what happens, Larry?
    Oct 2007
    sin city,ma
    valve cover gasket
    what???? im not larry....
    Jun 2005
    valve cover gasket
    Just a Lebowski reference...
    It could be a whole bunch of things... Some minor, some huge pains in the ass... it's hard to say.
    Are you comortable working on it?
    You could pull the cover to look for obvious signs of heat/pressure... you could run some compression tests, etc.
    It could be as simple as a new gasket. It could be much more involved. Do you have a good assortment of hand tools? The shop manual? Both are really good to have. It's not rocket science... you can definitely figure it out... just takes the rght tools and some patience.
    Oct 2007
    sin city,ma
    valve cover gasket
    yeah hopeully im gonna take the top off toorrow if i can get the time
    Oct 2007
    sin city,ma
    valve cover gasket
    just went out there to empty the oil catch i have under the bike and looked at the oil level it seems its still full could there being to much oil in there cause it to happen?
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    valve cover gasket
    Its not venting
    look for kinked vent hoses leading up into the air box
    there is also a PCV valve somewhere that could be clogged shut
    access spray clean
    Also examine the 1/2 moon and it should have little edges like a curb to prevent blow out
    When I install them I solvent clean area and then a tiny coating of
    black silicone
    Glen Beck is John the Baptist
    Nov 2007
    valve cover gasket
    Quote Originally Posted by trickphoto View Post
    DO YOU SEE WHAT HAPPENS WHEN YOU FUCK A STRANGER IN THE ASS!?!?!?
    Zip-Tie Alley Racing
    LRRS/CCS #103
  1. RTV for clutch cover gasket
    By Petorius in forum Bike Maintenance
    Last Post: 04-03-16, 11:03 AM
  2. Replies: 6
    Last Post: 12-07-11, 08:21 AM
  3. Head Gasket Question
    By HikerLT in forum Bike Maintenance
    Last Post: 03-28-09, 12:50 AM
  4. PITA valve cover gasket instal.
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-19-09, 06:52 PM
  5. Gasket help
    Last Post: 04-01-06, 04:18 PM
