Results 1 to 5 of 5
HELP!! Can't crack open the lower case!!
    Junior Member smd753's Avatar
    North Hampton, NH
    I'm fixing second gear on the bike.
    So I've pulled all the bolts that hold the lower case onto the engine of my '97 ZX9R, but I can't get the lower case to break free. Right now the engine is sitting in the shop with a lever jack on the clutch side pushing against the upper and lower halves. I've used a propane torch to heat up the gasket, but it hasn't broken free yet.
    HELP!!!
    And before you say it, yes, I made sure all the bolts have been pulled.
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Re: HELP!! Can't crack open the lower case!!
    Deadblow/rubber mallet and heat -- helps a lot to do this after the engine has been running a while. Position a 1" wooden dowel on the cover tabs (extending through the other side of the bike) and tap on it.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Dead blow hammer
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    Dead blow hammer
    This.
    Dead hooker
    this
  1. For Sale - Other | free case mate case for ipad air 2 PINK
    By tsorfas in forum For Sale
    Last Post: 09-21-15, 05:54 AM
  2. Found a crack in lower case.
    By smd753 in forum Bike Maintenance
    Last Post: 01-05-12, 11:32 AM
