Results 1 to 18 of 18
Can someone help me fit race plastics ??
    Nov 2007
    It's time for me to fit my new ArmourBodies track plastics on the r6... I've never done it before and I want to be real careful drilling all the holes, cutting the slider holes, etc etc.
    Does anyone with some experience doing this want to come by some time this week asap and help me do it? I'll provide food and beers/sodas as well as my appreciation.
    Also... I've got the Dzus fasteners and a 2" hole saw for the frame sliders... do I need anything else?
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Lifer union's Avatar
    Blackstone, MA
    Re: Can someone help me fit race plastics ??
    Did I tell you how happy I was when Pete told me you were doing the bodywork yourself? I had your bike on the lift, all the parts laid out and I was pulling my tool box over when he gave me the good news
    Oh ya. Get a uni bit for drilling. Its much easier.
    James
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    get some duct tape. tape both sides of the lower fairing where you plan on drilling your frame slider holes. this should stop splintering of the fiberglass
    -Benjamin Franklin
    Nov 2007
    Yeah... I want to learn these things so I can always do them myself in the future... I'm sure I'm capable of doing it myself... but I just want to do a good job and someone who knows what they're doing to lend a hand this first time I do it would be nice.
    Uni bit?
    Quote Originally Posted by daviid View Post
    Good tip, thanks
    LRRS/CCS #103
    and dont forget that laser idea i told you about yesterday in your garage built for mini-me
    Jun 2005
    Quote Originally Posted by ceo012384 View Post
    Uni bit?
    Blackstone, MA
    Quote Originally Posted by trickphoto View Post
    Yep that be them. Saves you from having to swap bits and they will drill through the fiberglass easy and the subframe if you have to. I had to.
    Also clamps to hold the bodywork together so you get holes in the same spot for the dzus fasteners. A pencil or marker. The tape is a good idea but if youre getting the stuff painted you really wont need it. Who ever paints it will clean it up for you if it needs it. I didnt have a problem with it splintering.
    James
    Nov 2007
    Word.
    Hmmm why would you need different sized bits? All the Dzus fasteners will require the same size hole, no?
    I have lots of clamps...
    Up at the fairing stay did you just drill two holes on each mirror spot and use zip ties or what?
    I'm anal/ocd and want it to be perfect...
    edit: btw bike and everything are in Wayland, MA... not in the city.
    LRRS/CCS #103
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    Word.
    its a race/track bike .... you will crash it as soon as the new body work is put on ... don't worry too much about it
    Blackstone, MA
    Word.
    Dzus fasteners hold to bodywork together not to the bike. Youll need to drill the fender, part of the tail, and some of the upper to mount it to the bike. You will also need to drill for the windscreen and for the spot the mirrors went that are held with zip ties. Feel free to come by the during the week to see what I did with mine.
    James
    Lifer BostonSVkid's Avatar
    Dec 2005
    I have installed these types of faiings before. If I get the trumpet up and running I will run down and give ya a hand.
    2006 Ducati Monster S2R800
    Foxboro, MA
    Quote Originally Posted by s a x m a n View Post
    there's always one chris... dont let the saxMAN keep you down
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Nov 2007
    you said the 'C' word!!!
    Ahh right, gotcha.
    Cool man thanks. Denno said he'd help as well so I'll letcha know when we're gonna do it and if you can make it, cool come have a few beers, otherwise, no worries.
    LRRS/CCS #103
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Not sure what Catch was refering to.
    The link requires a user id. Well here's a tip for the sliders.
    get some silly putty
    put the bolt for slider into the engine mount hole
    or where ever it goes... then put the silly putty where the slider
    will go through on the inside of the body work. then fit the body work on
    and tap the bolt into the putty when are at the right position.
    Now you got an impression of the center mark.
    2008 Honda CBR 600RR
    Dec 2005
    Let me know. The trumpet should be up and running tomorrow as my new o rings came in for the quick disconnects on the tank.
    Member Brit-Triple's Avatar
    I had to do that for a buddies 600rr, the tricky part was the inside of his fairing has insulation/foam on it. I used the bolts supplied for sliders at first, with some touch-up paint (or white out whatever you have lying around) to make the center mark. The step is good as you need to make so many holes in other things. I do have a portable drill press for straight drilling if you need to borrow, just pm me. I did a pilot hole from inside out, and then used the hole saw for the outside in. It may not matter as you will get it painted, but you do carpentry and should always cut from finished side to hidden side so tearout goes away/at a minimum. If you forget that, when you are not working on something that will get refinished, you won't be happy. Masking tape on out side helps out greatly.
    For the side with alot of insulation, a buddy recommended getting a dowel that fits into bolt hole snug. Take bolt to lowes and get one cheap, or you may have one in the house. Cut it to length, and sharpen like a spike, set in place then push fairing onto it. The indent hole will act as pilot mark.
    here is 600RR, came out great first try. Have tools and wagon, live in W Rox, you need a hand pm me we can carpool to your bike if needed. (never have done this for the other race stuff you mentioned)
    Carl
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Quote Originally Posted by Crash Dummy Denno View Post
    Make that 2 : Fresh paint is like a magnet for the pavement. Just bustin on ya...but seriously, I wouldn't worry about it being "perfect" they are track plastics and the less you think about how pretty they are the more you'll be able to thing about your riding.
    Zip Tie Alley #237
    Nov 2007
    Quote Originally Posted by hammadown View Post
    Yeah I know what you're saying....
    ... but do you know me? Have you seen my little OCD garage?
    LRRS/CCS #103
  1. Wanted - Parts & Tools | Race plastics for a 1st Gen SV
    By South of Heaven in forum Wanted
    Last Post: 01-16-15, 09:37 AM
  2. 99 R6 race plastics?
    By norco4hun in forum Wanted
    Last Post: 02-14-12, 02:46 PM
  3. Race plastics 06/07 r6
    By Gotthefeelin in forum Wanted
    Last Post: 05-10-11, 08:54 AM
  4. wtb: 2nd gen sv650s race plastics
    By Sportygurl131 in forum Wanted
    Last Post: 04-25-11, 06:24 AM
  5. 03 GSXR 1k Race Plastics
    By BMFR6 in forum For Sale
    Last Post: 04-04-10, 08:36 AM
