Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Help needed: Harley no-spark situation
    rides bikes
    Nov 2014
    Re: Help needed: Harley no-spark situation
    Quote Originally Posted by zombie View Post
    I'm leaning towards a ground problem
    Having owned a number of older harleys , in my experience it's always the wiring thats the weak point due to vibration.
    I had a similar issue on my old dresser and it turned out to be a bad ground , took me forever to find it,turned out it was the radio was the culprit
    I started by disconnecting everything that wasn't necessary to make the bike run and then worked backwards from there.
    Good luck , but on a positive note you own the best motor ever put out by harley , totally dead nuts reliable
    Thanks Mick! Sounds very similar to what I've got going on. I think my grounds are all good...but I've said that before.
    sorry hes been out with the flu.
    talked with another tech. nothing jumped out at him though. tough to diag over the interwebs.
    pulled a 93 manual though and theres a whole section on the ignition system and testing for no spark conditions.
    i can try to scan and email it if you give me your address.
    rides bikes
    Nov 2014
    Thanks for your help! I'll send you a note on that manual...I have one too, but it sounds like yours is better.
    My dad has a Evo motored Harley way back when. Ignition coil let go from vibration. But you replaced the coil. So I'd say ground as well.
    Lifer GMAN226's Avatar
    Coventry RI
    If you want to sell it let me know
    Gerard
    rides bikes
    Nov 2014
    Quote Originally Posted by GMAN226 View Post
    Hahah...it'll very likely be on Craigslist in the Spring
    sent
    rides bikes
    Nov 2014
    You're the man
  1. Need some eyes on my foot peg situation...
    By xxaarraa in forum General Bike Related
    Last Post: 08-30-17, 11:50 AM
