does anyone here have one that i could borrow?
no i ment for a motorcycle looking through the manual it says i need a clutch pressure plate tool to hold it while loosing the clutch sleeve hub nut
If you're using an impact wrench you should be able to just leave the old plates in there grab onto the outside of the basket with your hand and zip the nut off.
If your using hand tools you can take a couple of the old steel plates and a pair of vice grip pliers and make your own tool.
Double check - it may be left handed...
SSearchVT
i dunno what a clutch pressure plate tool is, but i managed to change out my plates without one i guess
"Chatbox...It's like Vegas, for your fingers."
Originally Posted by CBR_Knight
in my own thread, let me post this:
first of all, nothing about sex or play with a female seems interesting or arousing to me....
"BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
To remove the hub you'll need a clutch tool, but just to remove the pressure plate you don't need one.
Actually, if you have an impact wrench you don't need the clutch tool either.
2003 ZX7R
1995 916
ok seems that i dont need it when i took everything apart i got it off with out it
