Results 1 to 11 of 11
Need fork removal tools in Fitchburg
    Senior Member spydah's Avatar
    Fitchburg, MA
    Anyone got the center post torx bits for the ignition and/or spanners for the stem bolts that would be willing to allow me to use them for a few minutes?
    LRRS #831 Novice
    2007 Ducati 1098 - Street (okay, sometimes track)
    2002 Suzuki sv650 - Pure track!
    2007 Suzuki sv650 - Next seasons track bike
    http://www.myspace.com/spydah77
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    Re: Need fork removal tools in Fitchburg
    home depot, lowes, harbor freight, autozone, advance auto, pepboys. make your pick. they are called Security Torx bits.
    -Benjamin Franklin
    Fitchburg, MA
    Quote Originally Posted by daviid View Post
    I'll try HD tomorrow. Hopefully they have spanners there too. Seems like a fairly primitive tool these days.
    LRRS #831 Novice
    Just Registered
    Is it not obvious?
    Believe it or not, try Wal-Mart, look at the Stanley Torx set - I am pretty sure they are centerdrilled up to a certain size. I remember thinking it was odd that the packaging said nothing about this but they were def. sec. torx.
    Spanner? take a measurement and check the plumbing aisle
    If you can wait till Friday I can help you...but I suspect you want this done by then
    www.gpsdiscussion.com
    motorcycleaddicts.org
    a big drill bit
    Ok in all seriousness, you dont need the torx bits to get the forks off or even the triples off, just unplug the ignition switch. if you are looking to remove the IS then you could use a drill bit if you cant find the torx bits.
    as for the spanner, those usually arent on there very tight so a flat head screwdriver or drift and a mallet should be all you need.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Spanners. Take some flat steel. Drill holes in both ends approx 1/4 inch opening. On one end put a bolt and nut that they pivot on and on the other end two bolts and two jam nuts with some thread protruding. Free with stuff you find lying around.
    Fitchburg, MA
    All set guys, thanks for the suggestions. Found a security Torx set at sears. Now I'm part of the elite and I can take bathroom stalls apart too!
    Channel locks worked just fine on the stem nuts, duh!!!!
    LRRS #831 Novice
    While your in the bathrooms don't eat the mints.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Quote Originally Posted by spydah View Post
    So you the one!
    I just had to buy a T40 Security 3/8" socket yesterday too!
    2008 Honda CBR 600RR
    I've heard that you can knock out the center post in the screw heads and just use a regular torx bit. Never tried it myself but it could work in a pinch.
    I got my set at Sears too. It's easier to use than my other set that has the reg. torx bits so I just keep the new one in the tool box
  1. For Sale - Parts & Tools | Tools: Tusk Crank Puller, Motion Pro Spanners/Ringer/Fork Drivers
    By Tekime in forum For Sale
    Last Post: 10-31-20, 11:15 AM
  2. For Sale - Parts & Tools | Fork service tools
    By jeantarrou in forum For Sale
    Last Post: 03-01-17, 04:09 PM
  3. Man dies in Fitchburg Motorcycle Crash
    By mace in forum General Bike Related
    Last Post: 09-10-11, 02:34 PM
  4. Replies: 7
    Last Post: 07-08-11, 11:07 AM
  5. New TL1000R From Fitchburg MA
    By spydah in forum Welcome and Intro
    Last Post: 03-29-08, 12:24 AM
