Results 1 to 12 of 12
hid help
    wus good pimpin Truth's Avatar
    Oct 2007
    sin city,ma
    hid help
    ok so i just put a set of hids in the bike there 10k. the problem im having is some times one will cut out. i already put a 25 fuse in there for them and was told i may need to put in a relay does anyone have any advise? anyone have to put in a relay? does any one have any advise on size and where to put a relay?
    Re: hid help
    that's happening to my friend on his 8k kit. we havent pulled the front end apart to look at the HID kit yet.
    thinking it may be an overheating problem
    Oct 2007
    sin city,ma
    Re: hid help
    i thaught that at first but where my ballast are is right under my intake tubes and i cut a little off the bottom so they get air flow. the other thing is if i shut them off and turn them right back on the one that goes out will come on.
    Re: hid help
    exactly whats happening to my friend. think you have enough vent space?
    Oct 2007
    sin city,ma
    Re: hid help
    ill have too check it out
    Re: hid help
    FYI, there's thread for a group ride for satuday. i'm putting one up tomorrow for a Sunday ride. probably going to newbury tonight. let me know if you're interested
    Manchester, NH
    Re: hid help
    That happened to me on my Ninja. The ballast slowly died and needed to be replaced. Eventually it would not even spark the bulb. I hope its not the case for you, but it was for me.
    Lifer JohnnyV's Avatar
    Westborough, MA
    Re: hid help
    I have a really hard time figuring out why people put the 8k/10k/12k hid kits in their cars and bikes. Isn't the intent of doing an HID conversion to improve visibility? With 4300k being optimal for producing the most visible light to the human eye, anything far beyond that is purely for "show". But perhaps that is in fact the main motivating factor for some. Driving with blue lighting in anything but 100% clear nights renders them practically useless.
    san fran
    Re: hid help
    Quote Originally Posted by 02Telefonica View Post
    they are riding to newbury st to pose. and we all know chics dig purple lights.
    Tuono
    Manchester, NH
    Re: hid help
    I had 6K in my Ninja and that is about as blue as high as I would go. My bike was blue and it gave a mean HID look, but they were still bright as hell.
    To each their own.
    And I'd be careful about upping the fuse too much, I know HIDs only draw additional current when they spark, but you don't want to melt a wiring harness.
    Apr 2006
    Beverly, MA
    Re: hid help
    Sounds like either your bulb or ballast is defective. I'd exchange it. Also, have you measured the voltage at the headlight wires to make sure it's not dropping below 12.5ish?
    In all seriousness, I would get a 6k kit TOPS. Once you get above that HID temperature the light output falls to less than a standard halogen bulb. On top of that, the super high temp HID bulbs make you a massive cop target.
    If you want to stop by my house I'll help you take a look. I've done a few HID installs on cars.
    Oct 2007
    sin city,ma
    Re: hid help
    thanks for everyones input they are fine now just needed a little more air where the ballast were mounted. as for the light output i think there fine both in fair weather an bad rain that ive ridden in with them
