Ok, here's an odd problem.
I changed the oil on my '02 F4i Saturday. Bike was running fine, in fact, I let the engine warm up for a few minutes before I changed the oil and filter.
Once I tightened everything up, I looked at the oil level window and NOTHING. I thought, WTF, that's odd? But I'll see what it looks like after I let it run for a few minutes. I then realized that I was viewing the window while the bike was on the side stand... When I stood the bike up straight, the Window level shows it full.
Now the bike won't start. I killed the freaken battery trying to get it to start! Let it charge all day Sunday and just tried it again. NO LUCK!
The oil light came on while trying to start it, but I figured that was normal until oil got pumped into the new filter.
Any thoughts on what's wrong?
TIA!
--Brad
2010 BMW S1000RR - Soon to be track dedicated!
2006 BMW K1200 R
2002 Honda CBR 600 F4i - Trackbike - SOLD
2003 Kawasaki EX 250 - Hers
2008 Toyota Tacoma TRD - Sport
I can still walk around in my garage, I need more toys...
Poss a sticky kick stand Kill switch or Tip over sensor Junked Out....even if there was way too much oil in it it would start and run. Check all the wires and plugs you may have knock one off a bit??
Had a bud who lent his bike out and the dude filled it with oil Like FILLED and then rode it it just was Pissing out the exhaust....so
Tap the sensor a few times may allow it to start.....
LRRS EX 66
factoryeffex
I didn't... Didn't read about that until AFTER I had the problem...Also, when you installed the filter, did you put some oil into it first?
2006 BMW K1200 R
U can and it helps but isn't gonna stop it from starting....
LRRS EX 66
factoryeffex
just a thought, like they said the oil pressure shouldn't keep it from turning over....but just in case you dont already, its a good idea to measure out the oil as you pour it in. I've never had any luck or trust using a sight glass or dipstick.
Ah, see, I'm the opposite, I always say to go by the dipstick or sight glass rather than fluid measure. You never know how much you have left in the motor after an oil change, but the level as indicated by the dipstick/glass is always right. I'm the same way with forks, measure oil hight from the top rather than put in a set amount.
Is the starter spinning?
Do you hear the Starter wheezing at all?
Do you hear the fuel Pump turning on?
Zip Tie Alley Racing #444
Signature edit by Tricky mike
no kiddin....makes sense, I've just never had any luck...especially with the POS dipsticks on my R6's. Reading it is next to impossible cuz the entire thing is always covered in oil (and no I don't put way to much oil inlol). I just drain it really thoroughly and measure it out.
You might of just flooded the engine.When I did some work on my 05 cbr a couple months ago I started and stopped the engine a couple times. When i got the bike back together I couldn't get it to start at all. It would try but just wouldn't fire up. My problem was I flooded the engine. It took 2 times of draining the battery and recharging before it started. On the cbr if its flooded you have to hold the throttle at wide open when starting it to clear out the excess fuel. I would give that a try.
I got it running...
Like a dumbass, I tried to do too many things at once. I had the upper front cowl removed at the same time. Some how, one of the wire harness connectors loosened up and became disconnected.
As soon as I put the front cowl back on, the bike started right up...
Thanks for the advice guys...
2006 BMW K1200 R
LRRS EX 66
factoryeffex
Check the condition of your battery just the same and it's fluid levels.
