Results 1 to 7 of 7
ignition key electrical
    Do ignition key assemblies have electronics that can be damaged by lube?
    I have an older 95 FZR600 commuter that sits outside, and the key position keeps getting stuck in the off position...needs a lot of jiggling and key bending to make it to on...was going to try a squirt of lube before getting a new lock and key set
    I figure if it works - free fix. If not, why not replace the new lock and key set with a newer R6?
    Re: ignition key electrical
    Get some dry graphite lube, it'll lubricate without without trapping dirt/grit like a wet lube would.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    WD 40 wouldn't be bad too, just don't flood the lock 'cause as Josh said it will attract dirt and debris. BUT it will loosen and lubricate.
    Posted by Jane in BoxChat
    Senior Member MarkMarine's Avatar
    May 2013
    On older bikes not really. Some of the newer bikes like the ducati with the chip in the key may, but if there is any concern you could always use some isopropyl alcohol and compressed air to "blast" the stuff out of the lock. The alcohol won't damage electronics. It isn't a "new" key is it? Some of the fresh keys aren't perfect and will stick in the lock until they break in. Sandpaper on the edges (not on the peaks, but the long edge if that makes sense) might take the burrs off.
    Yowza LaRNZ's Avatar
    Oct 2004
    Tewksbury , MA
    just lube the bag out of it and run your key in and out a bunch of times.
    .:|LaRNZ|:.
    Member TripleTaco's Avatar
    Aug 2009
    Southern NH
    Quote Originally Posted by LaRNZ View Post
    '96 DR350SE
    '00 KTM 200exc
    '07 Speed Triple - sold
    '98 YZ125 - sold
    WD-40 worked really, really well...it turns like new!
    much thanks!
  1. Went to Keyless Ignition
    By turbo in forum General Bike Related
    Last Post: 04-01-13, 03:32 PM
  2. ignition wireing?
    By frostic in forum Bike Maintenance
    Last Post: 01-28-10, 12:16 PM
  3. any one have a ignition box
    By lrrs428 in forum General Bike Related
    Last Post: 06-10-09, 04:28 PM
  4. Ignition?
    By Murphy_101 in forum General Bike Related
    Last Post: 05-22-07, 07:18 PM
  5. Ignition Wiring ??
    Last Post: 06-30-04, 07:54 PM
