Results 1 to 9 of 9
Spools on non threaded swingarm?
    KNEE DRAGGING BAGGER sedanman's Avatar
    Oct 2014
    Pawling NY
    Can the swingarm be drilled and tapped? 2007 Yamaha FZ6.
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Re: Spools on non threaded swingarm?
    I don't know about drilling it. I've seen people weld something on, and I've seen adjuster blocks with a hole for a spool. I think cycle cat made them.
    Jan 2012
    i would assume u cant drill and tap the swingarm because there wont be enough material ?
    New Haven-ish, CT
    I asked this question on another forum, since my CBR F4 doesn't have threaded holes. Rivnuts into swingarm for spools - Band Of Riders
    I ended up having a machinist I work with whip up some threaded tabs, and I pulled the swingarm and had the welder at work TIG them on.
    In hindsight, I probably would've just used the rivnuts, and then remove the spools before riding, if I was concerned about a crash ripping apart the swingarm. Or bought a swingarm pad stand. Oh well.
    The FZ6 has a centerstand though. And the kickstand is what drags first, not the centerstand.
    Confirmed: kick stand drags before center stand*
    Oct 2014
    Pawling NY
    I want paddock stands more for being able to do some work on the bike without it falling (front and rear wheel removal ). I want to lose the centerstand just because I'll no longer need it. The sidestand hitting first is suprising actually so that might get removed on track days. I had seen rivnuts mentioned and l can get them from work just wondered what people thought of drilling that large of a hole in the swingarm. The swingarm is probably much stronger than it needs to be to begin with.... right?
    Welding tabs on looks like a very sanitary solution.
    Last edited by sedanman; 08-17-15 at 12:16 PM. Reason: I'm old and posting from my phone!
    New Haven-ish, CT
    Your bike has a painted black swingarm, so the paint would need to be removed before welding. Plus, you'd need to actually remove the swingarm to get it welded, and to do that you'd need to suspend the bike somehow.
    I remove the wheels on my FZ6 without stands. Put the bike on the center stand, and then some wood blocks tall enough to lift both wheels off the ground under the header. I *think* I used a 6x6 and a 4x4 - way cheaper than stands, and takes up less garage space too!
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Axle block sliders or a pad stand.
    Is there a reason the area of the wheel adjustment blocks can't be drilled/ tapped for the same effect?
    Oct 2014
    Pawling NY
    If l drill the wheel adjustment blocks, l can't remove the rear wheel while on the stand.
    Last edited by sedanman; 08-17-15 at 06:04 PM. Reason: I'm old and posting from my phone!
  1. Rivnuts into swingarm for spools
    By MattR302 in forum General Bike Related
    Last Post: 02-20-14, 08:32 PM
  2. Rhino moto threaded bar ends
    By 01xj in forum For Sale
    Last Post: 04-18-12, 10:10 PM
  3. WTB: Rear Stand- Swingarm or Spools
    By MikeyZ in forum Wanted
    Last Post: 07-13-11, 08:59 AM
  4. Shogun Swingarm Spools/Sliders for Kawasaki
    By e30addict in forum For Sale
    Last Post: 03-18-10, 09:09 AM
  5. question about swingarm spools
    By F4Iguy in forum General Bike Related
    Last Post: 03-16-08, 12:20 PM
