Results 1 to 25 of 43
Impact wrench recommendations?
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    So the rear axle bolt on my Ducati is a bitch to get off.
    I have the proper socket, but at R4 after having somebody stand on the rear brake and standing on my 19" breaker bar, I finally had to borrow an impact wrench to get it off (thanks, Pinned).
    That isn't going to work if I need a quick wheel swap, so I'm reluctantly in the market.
    The torque specs to get it on are 162 ft/lbs....I put it on at 150 ('cause that's as high as my torque wrench will go and it just happens to line up with a hole the retaining clip can go in) and it must be double that to get it off, but that's just a wild guess...
    The most convenient would seem to be cordless, but a name-brand one (dewalt or Milwaukee) seems to be ~$250+ (because I don't have any other tools compatible with those power packs). El cheapo seems to be as low as $60. This is currently my only need for it so I'm tempted to ignore the "buy once, buy right" - but not if the thing doesn't produce it's advertised torque.
    Between corded electric and air driven, air driven seems less expensive, but I don't have an air source at home (or even a proper garage) so outside of the LRRS garages I don't currently have a way to use an air driven one.
    ...so I guess I'm leaning towards a corded electric one, I imagine myself tripping over cords but then again, if I'm running warmers I should always have a power source at-hand
    ..although price is still a deterrent there as the name brands are ~$200
    Thoughts?
    LRRS 919
    Sep 2013
    Re: Impact wrench recommendations?
    Oh, anticipating the question "why not get a bigger breaker bar or pipe" - I may do that but a) I'd like to make it a one man operation. B) I'm on the verge of needing to upgrade my rear brake if I don't go the impact route
    Small detail - the socket for the rear axle is a 1/2" drive, if you have any reco's for that size
    LRRS 919
    KNEE DRAGGING BAGGER sedanman's Avatar
    Oct 2014
    Pawling NY
    I have Milwaukee 18volt cordless tools. They are awesome. My 1/2 cordless impact gun will take lugnuts off an MCI tour bus, these are torqued to 550 ft lbs.! Home Depot has a deal where if you spend $299 or more you get 6 months to pay it off with no interest.
    xxaarraa
    Guest
    I have an Ingersoll Rand 18V cordless, very happy with it. Precisely the same reason I got it too, the SSSA nut is torqued very high and I got tired of the whole stand on rear brake and breaker bar thing.
    Lifer bbhzx10's Avatar
    Jul 2004
    North shore
    I've got Snap-On cordless and 1/2" pneumatic.
    I should have bought the Ingersol Rand, and I would have had money left in my pocket.
    2001 Silver ZX-12R... RIP
    2005 KDX 200
    The Harbor Freight electric impact guns are supposed to be really good for the price...
    $17 or so for a CH air fed unit from Tractor Supply, WITH the 3 year extended warranty when on sale.
    Are they any good? I have a $50 Craftsman 1/2" unit and it's rubbish. Unless the bolt/nut is 75 ft-lbs or less it doesn't do jack shit. And that's with a 3/8" air line and 120psi of pressure and a full tank...
    I think it's rated for 250ft/lbs or so, I've used it on nuts that I can't bust with a breaker bar so it's done well by me.
    xxaarraa
    Guest
    Ductard, the thing to keep in mind while using an impact on the SSSA axle nut - impact does tend to chew the edges of the nut over time. My stock nut did OK, but it was starting to get slightly rounded so I threw on a motowheels titanium nut and that seems to be deteriorating at a faster rate.
    Sep 2013
    Quote Originally Posted by sedanman View Post
    I have 3-4 of the Milwaukee 12 volt (M12?) tools. I would probably get their M18 impact gun if i decide to go the high quality cordless route.
    LRRS 919
    Sep 2013
    Is that because of impact gun or more the quality/fit of your socket?
    Not that I have a super - high quality socket....in fact it's tendency to tilt on the nut (when not under full load anyways) IMO is another reason to go with an impact gun instead of applying torque from 3 feet away....
    LRRS 919
    Oct 2014
    Pawling NY
    There are 2 versions of the Milwaukee gun at Home Depot. A base model and one with a brushless motor. Go brushless if you go. Also the new 18 volt charger will also charge m12 batteries.
    xxaarraa
    Guest
    It could quite well be the socket. Though my socket is a high quality 6 point impact socket (not just a regular socket). It's something gargantuan like a 46 or something, if I remember right, and I had to special order it, along with the adapter from 3/4 to 1/2 drive.
    Sep 2013
    Wait.....6 point? Your SSSA doesn't have a funky 12 point nut on it?
    I think all Ducs do, they require a special socket, ~$30 and up on Amazon.com
    That 6 point socket could be your problem...
    LRRS 919
    xxaarraa
    Guest
    12 point axle nut?! Might be a pani thing, the 848 had a 6 point nut.
    Here is my axle nut:
    MW Billet 6 pt Rear Axle Nut: 748-998, 848, SF 848, MTS1000-1100, S2R-S4RS, M796-1100, Mhe, Hyper
    Turns out it's not titanium. But that's what I got on there now.
    Sep 2013
    A 6 point socket does grip better, on a 6 point nut.
    But a 12 point socket on a 12 point nut (which is rare) is twice as many contact points.
    Where you get less torque is a 12 point socket on a 6 point nut. It seems like that application's best selling point is to save lazy people 1/6 turn of a ratchet to get the socket seated.
    From your link, here's what I'm talking about with 12 point nuts....although I'd recommend against billet aluminum, as you've experienced.....
    MW Billet 12 Pt. Axle Nut: 748-998
    LRRS 919
    Lifer golden chicken's Avatar
    Attleboro, MA
    Can't sway me from my IR air tools, but I have a compressor here at work. I love my milwaukee cordless tools, but I don't have their 1/2" impact gun.
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    I have the Craftsman C3 1/2" impact wrench. The new one with 300 ft/lbs. I haven't had something it can't take off yet. You're welcome to come check mine out and give it a go. I love it, don't even use my pneumatic gun anymore. The LED lights are incredibly handy. I bought some other C3 tools and the battery it comes with is awesome. I think I paid $150 a year ago for the kit but still a great deal IMO.
    Craftsman.com
    TWINS! xrocket21's Avatar
    Central Maine
    the thing about impact guns, is the less torque they have, the less useful they are
    I own ONE snap on tool, and its my impact gun.
    Oct 2014
    Pawling NY
    My Milwaukee 1/2 gun makes more torque than my Cummins! https://youtu.be/gZCtecwq5tc
    700 ft lbs.
    I disagree. If we're talking the wired 1/2" drive one, it's total shit. It couldn't take the lugs off my FWD passenger car. Avoid. Avoid. Avoid.
    I have a 1/2" drive Craftsman C3 system driver that works well assuming you load it up with a Li-ion battery, not the cheaper NiCad batteries they use to sell with that system.
    Truth told, I'd buy a different driver (maybe Bosch?). Except I already have a bunch of C3 system tools. Having them share batteries and chargers is handy.
    Lifer Falko's Avatar
    MoonTown
    My family just bought me a Crapsman professional 1/2 pneumatic for Father's day to replace my old C&H that I've had for 25yrs. This thing has over 700ftlbs in reverse, took some lug nuts off and barely went into heavy impact doing it. Pretty impressive. I know the OP doesn't want pneumatic, but thought I'd throw it out there.
    Hmm thanks. I was going to pick one up but I won't now! Appreciate the heads up..
    Sep 2013
    Well..at least HF is being true to their brand...
    LRRS 919
  1. Replies: 28
    Last Post: 12-05-14, 12:43 PM
  2. Replies: 5
    Last Post: 02-27-10, 02:28 PM
  3. impact wrench question
    By kermita in forum Bike Maintenance
    Last Post: 04-09-08, 11:08 AM
