So the rear axle bolt on my Ducati is a bitch to get off.
I have the proper socket, but at R4 after having somebody stand on the rear brake and standing on my 19" breaker bar, I finally had to borrow an impact wrench to get it off (thanks, Pinned).
That isn't going to work if I need a quick wheel swap, so I'm reluctantly in the market.
The torque specs to get it on are 162 ft/lbs....I put it on at 150 ('cause that's as high as my torque wrench will go and it just happens to line up with a hole the retaining clip can go in) and it must be double that to get it off, but that's just a wild guess...
The most convenient would seem to be cordless, but a name-brand one (dewalt or Milwaukee) seems to be ~$250+ (because I don't have any other tools compatible with those power packs). El cheapo seems to be as low as $60. This is currently my only need for it so I'm tempted to ignore the "buy once, buy right" - but not if the thing doesn't produce it's advertised torque.
Between corded electric and air driven, air driven seems less expensive, but I don't have an air source at home (or even a proper garage) so outside of the LRRS garages I don't currently have a way to use an air driven one.
...so I guess I'm leaning towards a corded electric one, I imagine myself tripping over cords but then again, if I'm running warmers I should always have a power source at-hand
..although price is still a deterrent there as the name brands are ~$200
Thoughts?
LRRS 919
Oh, anticipating the question "why not get a bigger breaker bar or pipe" - I may do that but a) I'd like to make it a one man operation. B) I'm on the verge of needing to upgrade my rear brake if I don't go the impact route
Small detail - the socket for the rear axle is a 1/2" drive, if you have any reco's for that size
LRRS 919
I have Milwaukee 18volt cordless tools. They are awesome. My 1/2 cordless impact gun will take lugnuts off an MCI tour bus, these are torqued to 550 ft lbs.! Home Depot has a deal where if you spend $299 or more you get 6 months to pay it off with no interest.
I have an Ingersoll Rand 18V cordless, very happy with it. Precisely the same reason I got it too, the SSSA nut is torqued very high and I got tired of the whole stand on rear brake and breaker bar thing.
I've got Snap-On cordless and 1/2" pneumatic.
I should have bought the Ingersol Rand, and I would have had money left in my pocket.
2001 Silver ZX-12R... RIP
2005 KDX 200
The Harbor Freight electric impact guns are supposed to be really good for the price...
$17 or so for a CH air fed unit from Tractor Supply, WITH the 3 year extended warranty when on sale.
I think it's rated for 250ft/lbs or so, I've used it on nuts that I can't bust with a breaker bar so it's done well by me.
Ductard, the thing to keep in mind while using an impact on the SSSA axle nut - impact does tend to chew the edges of the nut over time. My stock nut did OK, but it was starting to get slightly rounded so I threw on a motowheels titanium nut and that seems to be deteriorating at a faster rate.
LRRS 919
Is that because of impact gun or more the quality/fit of your socket?
Not that I have a super - high quality socket....in fact it's tendency to tilt on the nut (when not under full load anyways) IMO is another reason to go with an impact gun instead of applying torque from 3 feet away....
LRRS 919
There are 2 versions of the Milwaukee gun at Home Depot. A base model and one with a brushless motor. Go brushless if you go. Also the new 18 volt charger will also charge m12 batteries.
LRRS 919
12 point axle nut?! Might be a pani thing, the 848 had a 6 point nut.
Here is my axle nut:
MW Billet 6 pt Rear Axle Nut: 748-998, 848, SF 848, MTS1000-1100, S2R-S4RS, M796-1100, Mhe, Hyper
Turns out it's not titanium. But that's what I got on there now.
A 6 point socket does grip better, on a 6 point nut.
But a 12 point socket on a 12 point nut (which is rare) is twice as many contact points.
Where you get less torque is a 12 point socket on a 6 point nut. It seems like that application's best selling point is to save lazy people 1/6 turn of a ratchet to get the socket seated.
From your link, here's what I'm talking about with 12 point nuts....although I'd recommend against billet aluminum, as you've experienced.....
MW Billet 12 Pt. Axle Nut: 748-998
LRRS 919
Can't sway me from my IR air tools, but I have a compressor here at work. I love my milwaukee cordless tools, but I don't have their 1/2" impact gun.
I have the Craftsman C3 1/2" impact wrench. The new one with 300 ft/lbs. I haven't had something it can't take off yet. You're welcome to come check mine out and give it a go. I love it, don't even use my pneumatic gun anymore. The LED lights are incredibly handy. I bought some other C3 tools and the battery it comes with is awesome. I think I paid $150 a year ago for the kit but still a great deal IMO.
Craftsman.com
the thing about impact guns, is the less torque they have, the less useful they are
I own ONE snap on tool, and its my impact gun.
My Milwaukee 1/2 gun makes more torque than my Cummins! https://youtu.be/gZCtecwq5tc
700 ft lbs.
I disagree. If we're talking the wired 1/2" drive one, it's total shit. It couldn't take the lugs off my FWD passenger car. Avoid. Avoid. Avoid.
I have a 1/2" drive Craftsman C3 system driver that works well assuming you load it up with a Li-ion battery, not the cheaper NiCad batteries they use to sell with that system.
Truth told, I'd buy a different driver (maybe Bosch?). Except I already have a bunch of C3 system tools. Having them share batteries and chargers is handy.
My family just bought me a Crapsman professional 1/2 pneumatic for Father's day to replace my old C&H that I've had for 25yrs. This thing has over 700ftlbs in reverse, took some lug nuts off and barely went into heavy impact doing it. Pretty impressive. I know the OP doesn't want pneumatic, but thought I'd throw it out there.
