I have one for a EX500. Check and see if it'll fit your application and it's yours to use.
i need one for an 01 SV650 too
Just a heads up alot of bikes you can et away with using a regular bolt from the hardware store. I had one bike that the front axle was the same size as the threads on the front axle and that's what I used. It was a Yamaha special 400.
Good luck.
Forgive my ignorance, but where does the flywheel puller attach in that photo?
forgive my curiousity... but why is the Z flywheeeeeeeeeel getting pulled?
Brent LRRS #772
2006 KTM 560 SMR
Is someone making themselves a Supebike???
CCS/ASRA Pro
2010 Yamaha R6
i want to put an advance key in mine.... and ....ummm... other stuff![]()
ive tried your bolt theory KB and i couldnt get it to work. i would rather just use the right tool for the job
