Results 1 to 25 of 47
Nesr r6 wisdom
    "Plymouth's Fastest" BrianC's Avatar
    Sep 2010
    Plymouth, MA
    Nesr r6 wisdom
    Hope everyone is having a good winter... I have been working on mah bike a little bit to pass the time and ran into a little problem. I finally put on a full exhaust, PC III, block off plates, and k&n air filter. I'm using the map for the bike/exhaust and have found that the bike Run like shit when cold. Won't idle until it's warmed up considerably, and then it's fine. Runs great, but sometimes surges at idle and stalls. I've searched the interwebz, synced the throttle bodies, and set the closed throttle position... any ideas? Do I need a Dyno tune to straighten this out? Bike is an 06 r6 w/9000 miles, and didn't behave this way before the new parts.
    LRRS am #121
    Re: Nesr r6 wisdom
    A dyno with a sniffer will be the best way to dial in the mapping. You may be able to correct it tweaking by hand but it'll be trial and error.
    Re: Nesr r6 wisdom
    you should be able to find someone with a similar map and use theirs.
    Re: Nesr r6 wisdom
    Did you mess with the idle adjustment and try to fix the issue???
    this:
    try holding the start button a bit longer, even as the motor starts to fire off, hold the button a second or 2 longer.
    DO NOT fuck with the little screw on the back of the throttle body unless you are prepared to buy a spare set off Ebay. once moved, you won't get the bike to idle correctly again if you mess with that tiny screw. It's way the heck out of the way for a reason. you can flash your ecu to up the idle, or go with a kit ecu/harness.
    and I would cross post this on the WERA13x forum as there is a lot of good wrench turners there and they know there shit my 2 cents
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    So you think its the map?
    LRRS am #121
    Re: Nesr r6 wisdom
    i doubt it's the map, but that's a quick fix that you can eliminate as one of the possiblities.
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Pigman, I wasn't aware fi bikes had an idle adjustment? Fill me in...
    LRRS am #121
    Re: Nesr r6 wisdom
    Posted above: just saw that in reading shit on WERA board.......just a thought
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    The only thing I haven't tried was to put the stock filter back in... the map says,"stock or aftermarket filter" so it's not specific. Maybe I'll try that.
    LRRS am #121
    Lancaster
    Wirelessly posted
    Throwing any fi lights?
    Corey
    Re: Nesr r6 wisdom
    How old is the gas in it?
    Re: Nesr r6 wisdom
    need me to sit on the bike nekkid again?
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Gas is from last September w/stabilizer in it. I think it could be part of the problem
    LRRS am #121
    Re: Nesr r6 wisdom
    Quote Originally Posted by BrianC View Post
    Me too. Especially the idle problem.
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Smutty, should I get some fresh fuel and add some injector cleaner or just straight fuel?
    LRRS am #121
    Re: Nesr r6 wisdom
    Either or imo.
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Thanks... I'll swap out the fuel and do another cold start and see what happens. If that doesn't do it, I'll swap air filters, and if that don't work I'll get a custom map on the dyno.
    LRRS am #121
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    Re: Nesr r6 wisdom
    I have an 06 also with all the mods you mentioned. IMO, you should get it custom tuned. KWS down in Charleston setup my bike and it runs flawlessly. Worth every penny, especially with the power curve improvements
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    I siphoned out the old fuel, ran it until all the old gas ran out and filled it up with fresh and went for a spin. Still runs good warm, but I am still getting a surging idle (goes up to 2200rpm then falls below 1000 and almost dies). I give it a couple revs and it idles good for a minute, then starts surging again. I have a feeling it is still going to run like shit when I start it up cold. It's got to be the map or air filter. I'll throw the stock filter in and see what happens
    LRRS am #121
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    How much does it cost for a custom map?
    LRRS am #121
    Aug 2012
    LA
    Re: Nesr r6 wisdom
    If I remember correctly, I paid just under $300 a few years ago. If you go that route, make sure you go to someone that knows what they're doing
    Re: Nesr r6 wisdom
    I got mine done at dyno solutions in ct. John is awesome and really knows his shit.
    Re: Nesr r6 wisdom
    The cost of a custom map at this point is all labor, $150 to $300 depending on how quickly it comes into it and how good the tuner is.
    Lifer union's Avatar
    Blackstone, MA
    Re: Nesr r6 wisdom
    I got mine mapped at Robs Dyno. We know what that pulled for power before it popped.
    I know my r6 used to idle a little rough when it was cold. It didnt surge but it was certainly cold blooded. Once a temp reading came up on the dash it would calm down and idle super smooth.
    James
    Re: Nesr r6 wisdom
    Gixxers and my 1K is like that too she will run ruff untill you get it up to temp and kida blown out revvvvved up then it GAME ON.
  1. The 20 commandments of motorcycle wisdom
    By VinceF2 in forum General Bike Related
    Last Post: 10-02-03, 03:50 PM
