OK so....
I am sick of wimpy motorcycle headlights. I have retrofit two 2.5in bi xenon projector beams. It will be amazing since I have tested the headlight and it makes basically daylight on the road with a super sharp cutoff at the top.
The problem is this.
I have 2 pos and 2 neg wires for the lights to light them up plus 2 pos and 2 neg to power the servo to open the trap door to make them high beam.
My stock light setup on my VTR1000 has only an H4 socket which provides one constant ground as well as pos 12v for low then pos 12v for high beam.
How do I use the stock HI/LOW beam switch for this. ??
My only solution was to provide constant 12 to the lights with a tap off the headlight fuse then use the power from the high beam for the trap door high beam.
Anyone have any ideas to help?
Can I put a diode (one way electric valve) to let both hi and lo beam power but not back bleed the power into the system?
I am gonna try to put the way I did this on utube as it is an amazing ugrade.
