Results 1 to 14 of 14
Knock from sprocket area
    Lifer rbrais's Avatar
    Brooklyn, CT
    I just had my tires replaced and now when I push the bike forward there is a knock that sounds like it is coming from the front sprocket area. It does not knock when I roll it backwards. The alignment sliders show that the axle is straight.
    Maybe the chain is a bit too tight? (I forgot to check that)
    Any ideas?
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Knock from sprocket area
    the Chain sounds like a viable option.
    Posted by Jane in BoxChat
    Brooklyn, CT
    Well that I know. It's the only variable from before the tire was changed. Just wondering if anyone has experience with this type of noise after the tire was removed/chain adjusted.
    Did they leave out the cushdrive?
    Westford, Ma
    wouldn't that make noise either way?
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    may be coincidental with tire change - I would check front sprocket nut... My speed sensor bolt backed itself out through the case, and this was same symptom (just worth a check).
    Brooklyn, CT
    I have to bring it back to have those rubber blocks replaced in the rear wheel. (not really sure what they are or what they do). I'll have them check it. Just ride the Shadow til then.
    I've only worked on dirtbikes, so not real familiar with streetbikes.
    Thanks everyone.
    Lake Champlain, VT
    they are cush pads...
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    Knock, knock.
    Who's there?
    Your sprocket.
    Nope, not OK
    LRRS #951
    My girlfriend wants to be like me when she grows up.
    Sometimes violence IS the answer. The answer every other time is busa.
    Thank you, I'm taking calls until 5.
    Brooklyn, CT
    Nothing major. Chain was just a little tight.
    Senior Member palanon's Avatar
    Nov 2008
    Epsom, New Hampshire
    Um, just a question. Did someone forget to replace the rubber pads in the cush drive? If so, who?
    " In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
    Brooklyn, CT
    I had the cush pads on order. Found out they needed changing when we took the wheel off, so I went a weekend on the old ones.
    Oct 2008
    Albany, ny
    Just a little FYI , if you pull the chain to tight and ride it . you can put to much tenshion on the output shaft, and it will make noise , usually a whiney sound.. thats bad.. shorten the life of trans and or bearings..
    Beat It Like A Rented Mule !!
    Legend in my own mind
  1. Knock knock
    By one2one2 in forum Welcome and Intro
    Last Post: 08-01-15, 11:15 AM
