Results 1 to 18 of 18
Little bit o'anti seize on the spark plug threads?
    Apr 2006
    Beverly, MA
    I'm about to swap plugs on my SV, and I wanted to see if there was any compelling reason to NOT use a little anti-seize on the spark plugs. I have a little packet of standard anti-seize that I was planning on using, but I heard I should use copper since the SV has aluminum heads.
    Thoughts?
    Oct 2007
    Peabody Assachusetts
    Re: Little bit o'anti seize on the spark plug threads?
    you should always use it IMO.
    I've never used copper or graphite anti-seize on my spark plugs in particular....don't see how it would make a difference unless you plan to keep them in there for 10 years...
    If you are going to use it, don't use the graphite-based anti-seize on the plugs as it doesn't withstand the extreme temps like the copper stuff does.
    Apr 2006
    Beverly, MA
    Good call. I should have a tube of it around anyway.
    Anyone else have any pearls of wisdom?
    You don't need alot.
    What you think you might need on those threads, use half that.
    Oct 2007
    Let me be a little more clear. I was not saying to use copper. I was saying that I always use the anti-sieze. The stuff I use is a silvery color.
    Senior Member MattyC's Avatar
    Apr 2008
    South Shore, MA
    Could it be Nickel? Nickel anti-sieze is sort of a dark silvery color and is good to 2400F. That should withstand quite a bit
    Waterbury, VT
    The copper stuff (high temp) is best to use on sparkplugs. That said - I have the regular in my garage and use it on everything. And as said before - just a little goes a long way with plugs. After I put it on the threads I wipe the face of the plug clean.
    SSearchVT
    Apr 2006
    Beverly, MA
    Quote Originally Posted by brendanp View Post
    Gotcha.
    I'll give the packet of stuff I have a read. If it doesn't seem like it's good for alum. I'll get a tube of the copper stuff. I might as well have both kinds around anyway. I can always use the gray stuff on lug nuts.
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    I've used it before when i've changed my plugs. You dont need a lot.
    Grease Monkey for Hire bergj1986's Avatar
    Feb 2008
    Brighton, MA
    I agree with bergs, I've never needed to use it on plugs because most people don't keep plugs in the heads for extended periods of time. You can run into trouble, however, if you use anti-seize that isn't rated for high temps and it melts itself into the threads of the plug and head. To avoid that, I just don't use anti-seize.
    Feb 2006
    Metro West, MA
    When in doubt, do what your MOM (Motorcycle Operation Manual) or your service manual says for replacing the plugs.
    That's GRAPHITE!
    Apr 2006
    Beverly, MA
    Quote Originally Posted by BadBoyBilly View Post
    I checked that and the service manual and I didn't see any mention of anti-seize. I think I may just skip it.
    Sep 2007
    Middlebury VT
    I have used it for many years.
    They make a specific type for spark plugs, look like a big crayon.
    Meets heat specs. etc.
    I find the plugs thread in really nice and always break free easily when I change them once a year. (old bike)
    Oct 2007
    I dont care what the service manual says... this is the old "ounce of prevention" rule....
    live to ride seth399's Avatar
    Feb 2007
    CA
    no need for anti-sieze
    They're not gonna listen...
  1. Cylinder #1 broken spark plug fixed!
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-16-09, 06:07 PM
  2. Spark Plug question
    By wfd38383 in forum Bike Maintenance
    Last Post: 07-25-07, 08:15 AM
