Results 1 to 25 of 29
Looking for cock information
    Senior Member Priv's Avatar
    Massachusettes
    Petcock information that is.... I'm not sure if I'm going to need a new one for my fuel tank. Went to dump the fuel out of my 250's tank and ran into a speed bump. Tipped the tank, and turned fuel to on, and watched no fuel empty. Then opened the cap just to be sure it wasn't a vacuum issue, and again, no dice. Is it possible that the petcock is clogged or something to that effect?
    Bopida Beepoo
    Senior Member FTMS's Avatar
    Warren, NH
    Re: Looking for cock information
    On the valve, does it say "prime or pri" on it? If it does you have a vacuum operated petcock and in order to get fuel out of it you will have to turn the lever to "prime or pri". There would also be a small hose connected to it along with the main fuel line.
    2004 Honda VTR
    1998 Honda VTR (Track Bike )
    1990 Honda CB-1
    1973 Yamaha RD350
    http://www.ftmsnh.com
    Massachusettes
    Quote Originally Posted by FTMS View Post
    Just took a look, and mine doesn't say either of these, just the usual on, of,f and reservoir options. Thanks for the info though
    Bopida Beepoo
    Lifer obsolete's Avatar
    Norf Sho
    It does however have a small hose and a main fuel line.
    -Alex
    Take the petcock off the tank, then let it drain through the new opening.
    Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    The small hose is a vacuum hose. Needs vacuum to allow fuel to flow.
    Norf Sho
    Concern is if the petcock is operating properly or not. I'm just concerned that we get the carbs all cleaned up and ready to be sync'd and the petcock is garbage and then we'd have wasted ours and someone else's time when we could fixed the problem now and be ready to go.
    -Alex
    Norf Sho
    So hooking up a hand vacuum pump will get it moving?
    -Alex
    Massachusettes
    Do you mean the entire thing? it does look like one of the hose connectors is removable....
    Bopida Beepoo
    Yeah, doesn't take much vacuum to operate the petcock. If the petcock is a concern I'd open it up and inspect it, real simple assembly. The primary piece is a diaphram that shouldn't be cracked, dirty, torn, etc.
    Don't lose the spring!!
    Norf Sho
    It probably works fine, just need to put some vacuum on it to check.
    -Alex
    Savannah, GA
    Yeah it probably does work just fine... the small hose is attached to a vacuum source... the big one is the main fuel line. Clean the carbs or whatever... a lot of people with ex500's put inline filters on there because there is no fuel filter from the factory.. not sure if the 250 is the same way. Something to keep in mind.
    The best advice I’ve ever been given is to not forget where you came from.
    You can use your "Special" Pump But clean it first
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Norf Sho
    Quote Originally Posted by BLACK SQUIRREL View Post
    You think I want another cock in that pump?
    -Alex
    Uxbridge, MA
    I have a Pet-Cock if you need to borrow it...
    Bullshit meter pegged scottfromboston's Avatar
    Oct 2009
    Maynard,MA
    Quote Originally Posted by Priv View Post
    You're going to have to suck.
    It will only take a few inches. (ha ha)
    ~Scott
    2020 SMC-R
    Oct 2009
    Maynard,MA
    Quote Originally Posted by scottfromboston View Post
    It's easy enough to create vacuum to prime the system by sucking on the small hose; it's isolated, so you're not breathing fuel. YMMV.
    Then again, I've had plenty of practice sucking at life, so a little hose is no issue for me.
    EDIT: Oh, you're trying to drain the tank. Yeah, that would take forever - pull the petcock off, or find a vacuum pump.
    Last edited by scottfromboston; 05-03-10 at 04:48 PM. Reason: Failure to pay attention to detail
    ~Scott
    2020 SMC-R
    When i drained the tank on my EX500, I just turned the petcock to reserve, sucked on the vaccuum hose to open the diaphragm, folded the hose over on itself & used a clip to keep it pinched.
    Took a while to drain it, but it worked.
    Norf Sho
    ...petcock... ...sucked... on the ...hose...
    Can you say that again, but slower?
    -Alex
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    I told ya Pete sucks!!
    www.bostonmoto.com
    Forum Rules
    Quote Originally Posted by The Magician View Post
    The 500's dont? My EX had a filter connected to the petcock, on both the reserve and main lines.
    there's no reserve line....
    Norf Sho
    Hmmmm... Somone filter the vacuum line?
    -Alex
    live to ride seth399's Avatar
    Feb 2007
    CA
    Pete, wanna come over and help suck my cock?
    LRRS #399
    MX #505
  1. Weds 10/20 MX101 Epping NH Your boss is a Cock
    By BLACK SQUIRREL in forum Dirty Bastards
    Last Post: 10-21-10, 08:28 AM
  2. COCK O THE NORTH BIKE RACING 2010
    By BE11WOOD in forum General Bike Related
    Last Post: 07-12-10, 10:26 AM
  3. i suck cock
    By naked-daytrader in forum General Bike Related
    Last Post: 09-24-07, 07:34 AM
  4. VIR information
    By s a x m a n in forum General Track Day Talk
    Last Post: 03-02-06, 10:17 AM
