Results 1 to 6 of 6
Loosing bearing cap for valve adjustment
    Lifer emayn15's Avatar
    Apr 2010
    OOB
    Is it common for the bearing caps to not slide up the locator dowels when you loosen the bolts? I've went a half turn on all the bolts now and there's a visible gap between the heads of the bolts but the bearing caps aren't coming apart from the head. From the way the service manual states it they should be coming right apart as there is spring tension pushing them away from the head and you gotta be careful to loosen all the bolts evenly so the caps don't get damaged. Doesn't seem quite right to me and I really don't feel like replacing the head if I screw it up.
    02 ZX750R & 08 KX450F
    Some will be under spring load and some won't. Don't overthink it. You may have to gently coax some of them up. Be careful as everything is aluminum.
    Apr 2010
    OOB
    Re: Loosing bearing cap for valve adjustment
    Thanks. Yeah that's my concern. It seems like it might need to be pryed apart or something to get it started and I don't want to go to far with loosening all the bolts if it isn't moving. I kind of got the impression from the manual it should be coming along as I loosen.
    No. It will stick a bit. The main thing it to bring everything up evenly as you don't want to warp the cam holder caps. Use a soft plastic pry if needed.
    Apr 2010
    OOB
    K. I'll give it another go around later see if I can get it to move. Thanks.
    Apr 2010
    OOB
    Thanks. Just got around to pulling them off today. No issues.
  1. SV-650 valve adjustment
    By NPDCPA in forum Bike Maintenance
    Last Post: 06-22-16, 09:00 AM
  2. First Valve Adjustment
    By Swizz in forum Bike Maintenance
    Last Post: 03-09-16, 08:41 AM
  3. Business | Valve adjustment
    By netputty in forum Business & Product Reviews
    Last Post: 10-24-12, 11:46 AM
  4. valve adjustment
    By j4eric in forum Bike Maintenance
    Last Post: 06-30-11, 02:25 PM
  5. Valve Adjustment
    By emayn15 in forum Bike Maintenance
    Last Post: 03-13-11, 05:22 PM
