Results 1 to 17 of 17
best lube for shift lever
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    OK so my shifter has felt sloppy and gross for a while so last week I pulled the rear set off Removed the shift lever. Then pushed out the stock steel bushing turned a new one out of 17-4 and pressed the new one in. Now my question is what should I use for lubricant. I had just slathered some white marine grease on there. But one of the guys at work suggested I use antisieze. He used to work at a chopper shop and said that's what they used. Doesn't sound so good to me though. Any thoughts?
    Re: best lube for shift lever
    I think antiseize should do the job.
    I like Bell-Ray grease..........light coat will be fine.
    I usually throw some general purpose lithium grease in there.
    Bell Ray waterproof grease.
    Waterbury, VT
    A waterproof grease would be my choice over anti-seize. Grease is designed for parts moving against each other. Anti-seize is for preventing static pieces from rusting. But - anti-seize is better than nothing...
    SSearchVT
    NoChelmsford, Ma.
    That was kind of my thinking. That's why I used the marine grease I'all pick up some of that bell ray water proof though thanks for the tips guys.
    Raymond NH
    I use Mercury 2-4-C lube. It's used on propeller splines underwater and seems about the best thing I've found so far. I've been meaning to drill it, tap it, and put a zerk on it...
    I drilled and tapped my shifter last year
    best lube for shift lever-38897_1319906611759_1653606918_822986_5601619_n-jpg
    ...inside the van. loudog's Avatar
    Central, MA
    Quote Originally Posted by sveesix View Post
    That's what I use too.
    Anti-seize is essentially a high-temp lube though...should work fine. Not sure about the weather-proofness though.
    Retired LRRS/CCS EX #212 | Woodcraft | Armour Bodies | Dainese USA |
    NoChelmsford, Ma.
    Yeah I didn't use the antiseize I used water resistant marine grease. The anti seize was just a suggestion I got from someone else.
    NoChelmsford, Ma.
    Oh while were on the subject I was thumbing thru my Haynes the other day and they reccomended a "dry film lubricant". Wth is that? Just a fancy way of saying graphite or what?
    Lifer NPDCPA's Avatar
    Mar 2011
    Quote Originally Posted by DaveZX6r View Post
    Kinda. Home Depot/Lowe's carry DuPont spray lubes that will fit the bill. Their dry lube is perfect for o-ring chains and absolutely will not fling. Works on squeaky door hinges at home, lock mechanisms and also your shifter. Will not attract grit.
    Derry NH
    They recommend a dry film lubricant because it doesn't attract dirt. The problem with a grease on something like that is it attracts and holds on to dirt, which damages the bushing. But that can be negated if you keep up with maintenance.
    I would say you would be OK with the grease you have on it, or a light coat of marine grade wheel bearing grease. Graphite powder would actually work well too, but may wash away.
    NoChelmsford, Ma.
    Cool thanks again guys. Btw I just put the rear set back on. Holy crap did that make a difference shifts like butter now.
    Lifer Expat's Avatar
    Mar 2007
    17/4 for a bush? Thats an expensive bush!!
    NoChelmsford, Ma.
    Yeah its what we had for steel lol.
  1. ttr125 shift lever
    Last Post: 10-21-12, 05:51 PM
  2. No clutch lever? No shift lever? No footpeg? No problem.
    Last Post: 08-29-11, 01:25 PM
  3. Need shift lever for 05/06 GSXR 1000
    By Ray-Ray in forum Wanted
    Last Post: 07-31-10, 11:04 AM
  4. Trumpet guys - shift lever needed
    By Nikon in forum General Bike Related
    Last Post: 06-21-09, 09:16 PM
  5. KLR pegs and shift lever
    By Nikon in forum Dirty Bastards
    Last Post: 06-01-08, 04:33 PM
