Results 1 to 4 of 4
timing retarder eliminators
    Senior Member double agent's Avatar
    Sep 2002
    acushnet - yates replica
    can you run a t.r.e and a yosh ems together? I think you could butI wanted to here from some other people who might have already done this.
    If money is the root of all evil,
    why do churches beg for it?
    Feb 2004
    Bellingham, MA
    Contact Ammar Bazzaz at Bazzaz performance. He has forgoten more about the suzuki's than all of us combined will ever know.
    Not sure if it helps you. But I have a TRE and a PCII on my Tiller...
    Winchester, MA
    Wouldn't that be sort of redundant? The timing advancer is just a drop in rotor that "tricks" the stock engine computer into advancing the timing by changing the positions on the pickup sensor wheel. I don't know much about the EMS but doesn't it allow you to change the timing map directly? If it does, you shouldn't need an advancer wheel, you can advance the timing right from the EMS.
  1. Track Day Lap Timing
    By lukebin in forum General Track Day Talk
    Last Post: 05-14-18, 10:28 PM
  2. Bad timing
    By Kurlon in forum Pit Area
    Last Post: 10-04-16, 10:43 AM
  3. Daytona live timing
    By xsiliconkid in forum Pit Area
    Last Post: 03-15-12, 04:47 PM
  4. Live timing
    Last Post: 09-04-11, 04:46 PM
