Results 1 to 25 of 34
Milky white sight glass
    ... victor24-7's Avatar
    Oct 2010
    Chicopee MA
    I have a 02 gsxr 600. Started it for the first time this yr. After running it for a min I shut it off to check the oil level and found white oil on the inside of the glass. The cap wasn't white. Also noticed after sitting the oil level went up from low to half. condensation? Or do I have a major issue here? Coolant in oil?
    Re: Milky white sight glass
    Probably didn't run it long enough to evaporate the condensation that naturally forms as the oil/ engine comes up to temp.
    Infected Slyder's Avatar
    Concord, NH
    Did it sit outside in the -100 temps all winter? If not, then I doubt it's coolant in the case.
    Let it come up to temp and then take it for a 10-15 minute ride and look at the glass. When was the last oil change? She's probably game for an oil change just the same, after storage.
    Oct 2010
    Chicopee MA
    Thanks for the tips. It sat in the freezing garage all winter. Took it down the street. Just got back and waiting. Still no white so I think it should be ok. Happened to my dirtbike before but this was a bit different. If I had coolant in the oil, would the white come back quick?
    Lifer Danz19899's Avatar
    Grafton, Ma
    thats a tricky one. check your coolant level, and what do you have in there for coolant?
    i say drain the oil, see how milky it is. if its completely milky you might have popped a freeze plug in the head on something
    www.bostonmoto.com
    Ride to live, live to ride
    Quote Originally Posted by victor24-7 View Post
    It wouldn't go away.
    Jan 2011
    Peyton Place
    Drain that acidic goo out and put in some fresh stuff.
    Yea...change the oil see if it comes back...
    Spray in some whipped cream, add a cherry and a straw and enjoy your shake.
    Oct 2010
    Chicopee MA
    The coolant is a bit above full in the overflow and the radiator is almost full.
    Grafton, Ma
    ya change the oil. Its actually antifreeze coolant in there right? not something that could have froze?
    www.bostonmoto.com
    Oct 2010
    Chicopee MA
    Had the valve cover off today. The freeze plugs were all in their place, well I didnt look for any issues while changing the valve cover gasket. Nothing floating around in there. Hope I'm just over thinking it.
    Grafton, Ma
    if thats the case swap out the oil and ride her a bit. probably just a lot of moisture build up from winter.
    butttt if it comes back its probably going to get expensive lol
    www.bostonmoto.com
    Oct 2010
    Chicopee MA
    Yes it's coolant in there. Had the water wetter drained and put in coolant before winter.
    Concord, NH
    You most likely are, coolant levels are good then it was most likely condensation. Give it some fresh oil and maybe add a little less.
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    just moisture. Very common. Even in fresh oil if you have a few temp changes in a week of sitting.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
    Lifer FirstDuc-1098's Avatar
    Central Mass
    keep Pete and some of the other guys away from your bike and you wont have milky white stuff on it
    Shit Corey says:
    Oct 2010
    Chicopee MA
    I'll check it tomorrow. My cbr didnt have this issue and it was sitting next to the gsxr all winter.
    Oct 2010
    Chicopee MA
    I cant really ride it in the streets because its my track bike(well was planning for it to be).
    I guarantee it does the same thing. Any engine that contains oil creates considerable condensation during warm up, even in the summer.
    The oil level issue going from low to half is because there is still oil within the engine that hasn't drained down into the pan after the engine was running. With oil that is not up to temp it could take as long as 5 minutes for it all to drain back down into the pan.
    This is a classic case of "Ride more. Worry less."
    Oct 2010
    Chicopee MA
    Just drained the oil. Gonna see tomorrow if there is water in it. If the water rises to the top.
    Water sinks to the bottom...
    Hey....all my GSXR's and others have the same issue....its from sitting, collects a bit of moisture in the motor...no biggie
    Ray Viernes, Scammer! Ray-Ray's Avatar
    Oct 2009
    Also,check your water pump.....a gasket or 0 ring might have gone...
    You CAN check all that stuff, but it's just a normal phenomenon as others have said. Ride it longer then check the site glass.
  1. Newbie to the sight
    By gixxerinct in forum Welcome and Intro
    Last Post: 05-18-04, 08:46 PM
